Required Event attribute is missing [message #582151] |
Wed, 25 March 2009 14:10 |
Timothy Marc Messages: 547 Registered: July 2009 |
Hey all,
i've started to work with Papyrus right now, and i have a really good
feeling by working with it. But i have a question concerning sequence
diagrams.
When create an BehaviorExecutionOccurrence, the start and finish
ExecutionOccorrenceSpecifications are created automatically, and due to
the UML spec, every EOS had to redefine the event association. But in
Papyrus it is neither possible to set this event, nor will this event be
set automatically.
I tried to manipulate the uml-file directly, bu that causes an
IllegalArgumentException with the following trace:
java.lang.IllegalArgumentException:
org.eclipse.uml2.uml.internal.impl.ReceiveOperationEventImpl @15c80a4
(name: RecvEvt1, visibility: <unset>) (visibility: public)
org.eclipse.uml2.uml.internal.impl.ExecutionOccurrenceSpecif icationImpl.setEvent(ExecutionOccurrenceSpecificationImpl.ja va:177)
org.eclipse.uml2.uml.internal.impl.ExecutionOccurrenceSpecif icationImpl.eSet(ExecutionOccurrenceSpecificationImpl.java:3 08)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1061)
at org.eclipse.emf.edit.command.SetCommand.doExecute(SetCommand .java:705)
org.eclipse.emf.edit.command.AbstractOverrideableCommand.exe cute(AbstractOverrideableCommand.java:129)
org.eclipse.emf.common.command.BasicCommandStack.execute(Bas icCommandStack.java:92)
org.eclipse.emf.edit.provider.ItemPropertyDescriptor.setProp ertyValue(ItemPropertyDescriptor.java:1400)
org.eclipse.uml2.uml.editor.presentation.UMLEditor$UMLProper tySource.setPropertyValue(UMLEditor.java:1850)
org.eclipse.ui.views.properties.PropertySheetEntry.valueChan ged(PropertySheetEntry.java:782)
org.eclipse.ui.views.properties.PropertySheetEntry.setValue( PropertySheetEntry.java:723)
org.eclipse.ui.views.properties.PropertySheetEntry.applyEdit orValue(PropertySheetEntry.java:146)
org.eclipse.ui.views.properties.PropertySheetEntry$1.applyEd itorValue(PropertySheetEntry.java:103)
at org.eclipse.jface.viewers.CellEditor$1.run(CellEditor.java:3 05)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
org.eclipse.jface.viewers.CellEditor.fireApplyEditorValue(Ce llEditor.java:303)
org.eclipse.jface.viewers.ComboBoxCellEditor.applyEditorValu eAndDeactivate(ComboBoxCellEditor.java:267)
org.eclipse.jface.viewers.ComboBoxCellEditor$2.widgetDefault Selected(ComboBoxCellEditor.java:146)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:112)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 06)
at org.eclipse.swt.custom.CCombo.textEvent(CCombo.java:1497)
at org.eclipse.swt.custom.CCombo$1.handleEvent(CCombo.java:102)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:975)
at org.eclipse.swt.widgets.Text.sendKeyEvent(Text.java:1299)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:971)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1285)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:3772)
at org.eclipse.swt.widgets.Text.WM_CHAR(Text.java:2018)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3672 )
at org.eclipse.swt.widgets.Text.windowProc(Text.java:2013)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4351 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 65)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
I think this a technical bug, may be a logical bug in the specification,
i don't know, because the intention of this required event-attribute is
not clear to me.
Thx
Timothy
FUDForum. Page generated in 0.05379 seconds
