Home » Language IDEs » PHP Development Tools (PDT) » Eclipse File System (EFS) and PDT -- Compatibility Problems
Eclipse File System (EFS) and PDT -- Compatibility Problems [message #58779] Tue, 16 October 2007 21:30 Go to next message
Hello, I'm writing a sftp remote filesystem browser for eclipse as an
extension of EFS. I was hoping it would be compatible with PDT. Are
there any known compatibility problems with EFS and anything in PDT? My
plugin causes a NullPointerException when I try to open a file. Stack
trace follows. Probably a shot in the dark but I'd appreciate any help.
--Thanks, Bret
org.eclipse.wst.sse.core.internal.FileBufferModelManager.cre ateURIResolver(FileBufferModelManager.java:419)
org.eclipse.wst.sse.core.internal.FileBufferModelManager.get Model(FileBufferModelManager.java:656)
org.eclipse.wst.sse.core.internal.model.ModelManagerImpl._ge tModelFor(ModelManagerImpl.java:393)
org.eclipse.wst.sse.core.internal.model.ModelManagerImpl.get ModelForEdit(ModelManagerImpl.java:1020)
org.eclipse.wst.sse.ui.StructuredTextEditor.doSetInput(Struc turedTextEditor.java:2113)
org.eclipse.php.internal.ui.editor.PHPStructuredEditor.doSet Input(Unknown
Source)
org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:2994)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2451)
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3012)
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3039)
org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredT extEditor.java:2615)
at org.eclipse.php.internal.ui.editor.PHPStructuredEditor.init( Unknown
Source)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:263)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2721)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:340)
at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:328)
at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:190)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Re: Eclipse File System (EFS) and PDT -- Compatibility Problems [message #58828 is a reply to message #58779] Wed, 17 October 2007 00:52 Go to previous messageGo to next message
Originally posted by: kevinjdoyle.rogers.com
Hi Bret,
The reason you are seeing this NPE is because WST Editors are not fully
EFS aware. Bug 196172 (
https://bugs.eclipse.org/bugs/show_bug.cgi?id=196172 ) is open for
tracking this issue. To fix this you can upgrade to WST 2.0.1. I
haven't had a chance to test it completely and since the bug is still
open it looks like WST isn't fully EFS aware still, but you can at least
open files with WST 2.0.1.
btw. You may want to check out the Target Management (
http://www.eclipse.org/dsdp/tm ) project. It's Remote System Explorer
EFS implementation supports sftp. This is what I am using.
Kevin Doyle
> --Thanks, Bret
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.php.internal.ui.editor.PHPStructuredEditor.init( Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Eclipse File System (EFS) and PDT -- Compatibility Problems [message #58873 is a reply to message #58828] Wed, 17 October 2007 11:55 Go to previous message
Thanks Kevin,
I updated to the latest version of WST and this seemed to fix it. I will
take a look at the Target Management project. Hopefully it is not like
most of the sftp plugins i've seen that recursively load the entire
filesystem into memory. I need something that will load directories on
demand.
Thanks Again,
Bret
Kevin Doyle wrote:
> Hi Bret,
> Kevin Doyle
>> My plugin causes a NullPointerException when I try to open a file.
>> Stack trace follows. Probably a shot in the dark but I'd appreciate
>> any help. --Thanks, Bret
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Previous Topic:Smarty & Questions
Next Topic:Quick fix no longer?
Current Time: Tue Jul 15 10:02:52 EDT 2025
Powered by FUDForum. Page generated in 0.06429 seconds
