Home » Newcomers » Newcomers » troubles with first launch of eclipse
troubles with first launch of eclipse [message #58762] Thu, 28 April 2005 03:19 Go to next message
Originally posted by: alethesnake.inwind.it
hi,
I've downloaded eclipse 3.0.2 for win32 and I've unzipped it into
c:\eclipse.
when I double click on eclipse.exe it answers with an error. in the log
file I read:
java.version=1.3.1_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
!ENTRY org.eclipse.osgi apr 28, 2005 08:55:34.99
!MESSAGE Error registering XML parser services.
!STACK 0
java.lang.ClassNotFoundException: javax.xml.parsers.SAXParserFactory
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at .....
my sdk is 1.5.
could anyone suggest me which is the problem?
thanks
Re: troubles with first launch of eclipse [message #58787 is a reply to message #58762] Thu, 28 April 2005 05:39 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
Yes. The problem is that Eclipse find an 1.3.1_01 vm on your computer
(java.version shows that in your log). You need to specify the java. Ie. if
you have 1.5 jdk installed in c:\jdk15 you should run Eclipse with the
following parameters:
eclipse.exe -vm c:\jdk15\bin\javaw.exe
HTH,
Csaba
exquisitus wrote:
> hi,
> c:\eclipse.
> file I read:
> !STACK 0
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at .....
> my sdk is 1.5.
> thanks
Re: troubles with first launch of eclipse [message #59013 is a reply to message #58787] Thu, 28 April 2005 10:20 Go to previous message
thank you very much!
It runs well
bye
Previous Topic:change workspace
Next Topic:SWT with Visual Editor
Current Time: Sun Jul 13 18:15:05 EDT 2025
Powered by FUDForum. Page generated in 0.08661 seconds
