Home » Eclipse Projects » Plugin Development Environment (PDE) » Re: Common Navigator Framework
Re: Common Navigator Framework [message #5245] Tue, 03 June 2008 11:13 Go to next message
(Moving to PDE)
Not sure why this is happening. The extension points show up the in the
dialog to allow them to be selected? And as you said privately, you
have org.eclipse.ui.navigator as a plugin dependency.
What do you do exactly to get this error?
Francis
Joe Hutson wrote:
> I�m working through Michael Elder�s CNF tutorials as a second pass at
> gaining some experience with the CNF. I am having trouble getting the
> manifest editor to find extension point schema and definition for
> org.eclipse.ui.navigator.viewer and
> org.eclipse.ui.navigator.navigatorContent. The error message is
> 'Extension point schema org.eclipse.ui.navigator.viewer cannot be found.'
> Eclipse version 3.3.2
> org.eclipse.ui.navigator is configured as dependency for my plug-in
> Any suggestions?
Re: Common Navigator Framework [message #5309 is a reply to message #5245] Tue, 03 June 2008 11:23 Go to previous messageGo to next message
In the manifest editor extensions tab right click on the extension and
select Show Description or Open Schema which works for other extensions
e.g. org.eclipse.ui.views
The real issue is that because the schema isn't accessible there is no
validation of sub-elements, right clicking on
org.eclipse.ui.navigator.viewer presents the developer with the option to
add a new Generic or new Extension and nothing else.
Re: Common Navigator Framework [message #5363 is a reply to message #5309] Tue, 03 June 2008 11:50 Go to previous messageGo to next message
I'm not a PDE guy, but can you check the .jar (in the plugins directory
of your installation) that contains the navigator,
org.eclipse.ui.navigator...jar. Make sure it has a schemas folder with
3 .exsd files.
Hopefully one of the PDE people can help answer this.
> to add a new Generic or new Extension and nothing else.
Re: Common Navigator Framework [message #5654 is a reply to message #5363] Tue, 03 June 2008 12:08 Go to previous messageGo to next message
The schema folder is not there. The schema attribute in the plugin.xml
(below) seems to indicate that it should be?
Jar Version: org.eclipse.ui.navigator_3.3.2.M20080207-0800
<?eclipse version="3.0"?>
<plugin>
<extension-point id="navigatorContent"
name="%ExtPoint_navigatorContent" schema="schema/navigatorContent.exsd"/>
<extension-point id="viewer" name="%ExtPoint_navigatorViewer"
schema="schema/viewer.exsd"/>
<extension-point id="linkHelper" name="%Link_Helper"
schema="schema/linkHelper.exsd"/>
<extension
point="org.eclipse.ui.dropActions">
<action
class=" org.eclipse.ui.internal.navigator.dnd.NavigatorPluginDropAct ion "
id="org.eclipse.ui.navigator.PluginDropAction">
</action>
</extension>
</plugin>
Re: Common Navigator Framework [message #5671 is a reply to message #5654] Tue, 03 June 2008 12:11 Go to previous messageGo to next message
That's bad news, don't know how it got that way, but you should
reinstall and hopefully that will fix your problem.
> <plugin>
> <extension
> <action
> </action>
> </extension> </plugin>
Re: Common Navigator Framework [message #5690 is a reply to message #5654] Tue, 03 June 2008 12:16 Go to previous messageGo to next message
No, I'm wrong about the schema folder needing to be in *that* jar file.
I found it in the source jar file (the one I was previously looking at
was one I built myself).
Do you have the _source plugin for the navigator?
(I'm just guessing here, we really need someone who understands the PDE,
I bet they could answer this in a second).
Francis
> <plugin>
> <extension
> <action
> </action>
Re: Common Navigator Framework [message #5741 is a reply to message #5690] Tue, 03 June 2008 14:02 Go to previous messageGo to next message
Upgrading to 3.4 resolved this issue, thanks for the help.
Re: Common Navigator Framework [message #5759 is a reply to message #5690] Tue, 03 June 2008 17:43 Go to previous messageGo to next message
Even tough I've been using PDE on a daily basis for over a year, I don't
really "understand" it. ;-)
But, I do know that if the user did not install the SDK or Eclipse for
RCP/Plugin Developers package, he won't have the source plugins for PDE.
That is probably why the manifest/plugin editor can't find the schemas.
I'd advise to get one of those packages that are specially built for
plugin development.
Hope this helps,
Eric
>> plugin.xml (below) seems to indicate that it should be? Jar Version:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <plugin>
>> <extension
>> <action
>> </action>
Re: Common Navigator Framework [message #5876 is a reply to message #5309] Mon, 09 June 2008 15:19 Go to previous message
To fix this, you could do this (if you are using Eclipse 3.3):
- Copy the following folder from the Eclipse installation's "plugin" folder,
into your RCP application's "plugin" folder:
org.eclipse.platform.source_3.3.0.v20070612-_19UEkLEzwsdF9jS qQ-G
This folder contains the source and the schema definitions. You may have to
restart Eclipse, and then you will be able to right-click and see the
correct options when you add extensions.
Re: Common Navigator Framework [message #567885 is a reply to message #5245] Tue, 03 June 2008 11:23 Go to previous message
Re: Common Navigator Framework [message #567915 is a reply to message #5309] Tue, 03 June 2008 11:50 Go to previous message
3 .exsd files.
Re: Common Navigator Framework [message #567930 is a reply to message #5363] Tue, 03 June 2008 12:08 Go to previous message
<plugin>
<extension
<action
</action>
</extension>
</plugin>
Re: Common Navigator Framework [message #567959 is a reply to message #5654] Tue, 03 June 2008 12:11 Go to previous message
> <plugin>
> <extension
> <action
> </action>
Re: Common Navigator Framework [message #567983 is a reply to message #5654] Tue, 03 June 2008 12:16 Go to previous message
Francis
> <plugin>
> <extension
> <action
> </action>
Re: Common Navigator Framework [message #568081 is a reply to message #5690] Tue, 03 June 2008 14:02 Go to previous message
Re: Common Navigator Framework [message #568113 is a reply to message #5690] Tue, 03 June 2008 17:43 Go to previous message
plugin development.
Hope this helps,
Eric
>> <plugin>
>> <extension
>> <action
>> </action>
Re: Common Navigator Framework [message #568468 is a reply to message #5309] Mon, 09 June 2008 15:19 Go to previous message
Previous Topic:Plugins Out of Sync
Next Topic:Re: Triggering updates?
Current Time: Wed Jul 30 08:50:30 EDT 2025
Powered by FUDForum. Page generated in 0.08543 seconds
