Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE build issues with multiple platforms
PDE build issues with multiple platforms [message #58704] Mon, 27 April 2009 18:12 Go to next message
Hi, All,
I encountered a build issue with multiple platforms. We have a feature
which has platform specific fragments, such as:
org.eclipse.core.filesystem.macosx
org.eclipse.core.filesystem.win32.x86
Both has set proper "Operating System" and "Architecture" information.
Then we created an update site, and include the feature. The problem is
that update site "Build" action doesn't include publish any macosx
plug-ins, just win32.x86 specific plug-ins. Therefore, the update site
works fine with Win32 program, but doesn't work with macosx program.
We do the Build inside eclipse on a Windows XP computer. Is there any
further setting needed to make it work?
Thank you so much in advance! Have a great day!
Best Regards,
Frank Du
Re: PDE build issues with multiple platforms [message #58857 is a reply to message #58704] Wed, 29 April 2009 14:17 Go to previous message
The update site build in the workspace only does one platform at a time.
You can do multiple platforms if you set up a headless build.
You could also try building the update site, go to the target platform
preferences and change the target to be a different environment, then
build the update site again.
-Andrew
Frank Du wrote:
> Hi, All,
> Best Regards,
> Frank Du
Re: PDE build issues with multiple platforms [message #596515 is a reply to message #58704] Wed, 29 April 2009 14:17 Go to previous message
-Andrew
Frank Du wrote:
> Hi, All,
> Best Regards,
> Frank Du
Previous Topic:JAR a feature from PDE
Next Topic:Do we need different update sites for Windows and MacOSX?
Current Time: Sun Jul 13 01:21:02 EDT 2025
Powered by FUDForum. Page generated in 0.05562 seconds
