Home » Archived » XML Schema Definition (XSD) » TextNode does not contain the TargetNamespace
TextNode does not contain the TargetNamespace [message #58674] Tue, 22 March 2005 10:46 Go to next message
Originally posted by: runinpanic.gmx.de
Hello
I have the following situation:
Using this Schema (the relevant part only):
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns="tests_localised_Schema"
targetNamespace="tests_localised_Schema">
<xs:complexType name="ct.alpha">
<xs:sequence minOccurs="1" maxOccurs="5">
<xs:element name="uno" type="st.uno" />
<xs:element name="duo" type="st.duo" />
<xs:element name="tres" type="ct.tres" />
</xs:sequence>
<xs:attribute name="opt" type="xs:token" />
</xs:complexType>
<xs:simpleType name="st.uno">
<xs:restriction base="xs:string">
<xs:enumeration value="hinz" />
<xs:enumeration value="kunz" />
</xs:restriction>
</xs:simpleType>
.... and reading a jDOM-object that is created using this Schema.
When getting the first TextNode (a jDOM "Text" object representing
"st.uno") I try to get the targetNamespace of the object using:
if (jdomObj instanceof Text) {
namespace = ((Text)jdomObj)
.getParentElement()
.getNamespaceURI();
The String "namespace" is empty ("").
Then I saw that this jDOM-object got its namespace from this code:
public ElementDeclaration(XSDElementDeclaration edecl, ...) {
String targetns = edecl.getTargetNamespace();
resultEle.setNamespace(Namespace.getNamespace(targetns));
Text txt = new Text(temp);
resultEle.addContent(txt);
checking the XSDElementDeclaration edecl I saw, that it did not hold a
targetNamespace (targetNamespace= null) but following the
"eContainer"-Attribute of "edecl" up to the complexType "ct.alpha"
taught me that the targetNamespace exists only in an upper level
edecl= XSDElementDeclarationImpl (id=33)
eContainer= XSDParticleImpl (id=116)
eContainer= XSDModelGroupImpl (id=142)
eContainer= XSDParticleImpl (id=151)
eContainer= XSDComplexTypeDefinitionImpl (id=158)
name= "ct.alpha"
targetNamespace= "tests_localised_Schema"
My question:
Is this correct? Is the targetNamespace not inherited from complexTypes
to hierarchically lower TextNodes?
Re: TextNode does not contain the TargetNamespace [message #58700 is a reply to message #58674] Tue, 22 March 2005 11:47 Go to previous messageGo to next message
Hajo,
I'm not sure what you are referring to with jDOM-object, and the code
you show that creates a Text node doesn't look familiar either. I don't
think Text nodes are supposed to have a namespace in DOM, so maybe your
question isn't valid. In any event, in your schema, the element
declarations are local declarations, and, by default, their form is
unqualified, so they will have null target namespace as defined in the
XML Schema specification regardless of the namespace of the schema or of
their containing complex type.
Hajo Hoffmann wrote:
>Hello
> </xs:sequence>
></xs:complexType>
> </xs:restriction>
></xs:simpleType>
> .getParentElement()
> .getNamespaceURI();
> name= "ct.alpha"
>My question:
Re: TextNode does not contain the TargetNamespace [message #58723 is a reply to message #58700] Tue, 22 March 2005 12:16 Go to previous messageGo to next message
Okay ...
maybe i should not have mentioned the jDOM-object.
The essence of my problem lies in the XSDElementDeclaration:
name= "uno"
> > name= "ct.alpha"
Why does the upper "targetNamespace" not contain
"tests_localised_Schema" while the lower one does? I hope the origin of
this structure is clear.
Why is the actual form of the Schema unqualified?
I double-triple-quadruple-checked it with Xerces :-/
Hajo Hoffmann
In article <d1pmug$95s$1@news.eclipse.org>, Ed Merks <merks@ca.ibm.com>
wrote:
> Hajo,
> >Hello
> > </xs:sequence>
> ></xs:complexType>
> > </xs:restriction>
> ></xs:simpleType>
> > .getParentElement()
> > .getNamespaceURI();
> > name= "ct.alpha"
> >My question:
Re: TextNode does not contain the TargetNamespace [message #58749 is a reply to message #58723] Tue, 22 March 2005 12:31 Go to previous message
--------------080604090006030407000905
Hajo,
The specification defines the value of the targetNamespace for a local
element declaration like this:
An element declaration as in the first case above, with the
exception of its {target namespace} <#e-target_namespace> and
{scope} <#e-scope> properties, which are as below:
Element Declaration <#Element_Declaration_details>* Schema Component*
Property Representation
{target namespace} <#e-target_namespace> If |form| is present and
its
Re: TextNode does not contain the TargetNamespace [message #594550 is a reply to message #58674] Tue, 22 March 2005 11:47 Go to previous message
Hajo,
>Hello
> </xs:sequence>
></xs:complexType>
> </xs:restriction>
></xs:simpleType>
> .getParentElement()
> .getNamespaceURI();
> name= "ct.alpha"
>My question:
Re: TextNode does not contain the TargetNamespace [message #594560 is a reply to message #58700] Tue, 22 March 2005 12:16 Go to previous message
Okay ...
name= "uno"
> > name= "ct.alpha"
Hajo Hoffmann
wrote:
> Hajo,
> >Hello
> > </xs:sequence>
> ></xs:complexType>
> > </xs:restriction>
> ></xs:simpleType>
> > .getParentElement()
> > .getNamespaceURI();
> > name= "ct.alpha"
> >My question:
Re: TextNode does not contain the TargetNamespace [message #594567 is a reply to message #58723] Tue, 22 March 2005 12:31 Go to previous message
Hajo,
its
Previous Topic:TextNode does not contain the TargetNamespace
Next Topic:Problem validating a reference to xsd:schema
Current Time: Wed Jul 16 08:13:31 EDT 2025
Powered by FUDForum. Page generated in 0.10300 seconds
