Home » Modeling » GMF (Graphical Modeling Framework) » Can't regenerate with GMF 1.0.1
Can't regenerate with GMF 1.0.1 [message #58659] Tue, 03 October 2006 09:13 Go to next message
Originally posted by: contact.noelios.com
I've just upgraded to Eclipse/Callisto 3.2.1 and when I try to
regenerate my "*.gmfgen" files from the map files, I get some weird
errors (see below).
Any idea how to fix them?
Jerome
Diagnosis of
org.eclipse.gmf.codegen.gmfgen.impl.GenEditorGeneratorImpl@1f523a3 {platform:/resource/com.supplyinsight.designer/model/source. gmfgen#Source}
The feature is already initialized by another 'GenFeatureValueSpec'
in the sequence
in the sequence
in the sequence
in the sequence
in the sequence
in the sequence
in the sequence
in the sequence
in the sequence
in the sequence
in the sequence
in the sequence
in the sequence
in the sequence
Re: Can't regenerate with GMF 1.0.1 [message #58683 is a reply to message #58659] Tue, 03 October 2006 10:06 Go to previous messageGo to next message
Hi Jerome,
It looks like your *.gmfgen contains a GenFeatureSeqInitializer with
multiple GenFeatureValueSpec
elements bound to the same feature.
/Radek
On Tue, 03 Oct 2006 15:13:29 +0200, Jerome Louvel <contact@noelios.com>
wrote:
> errors (see below).
> Jerome
> Diagnosis of
> in the sequence
> in the sequence
> in the sequence
> in the sequence
> in the sequence
> in the sequence
> in the sequence
> in the sequence
> in the sequence
> in the sequence
> in the sequence
> in the sequence
> in the sequence
> in the sequence
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Can't regenerate with GMF 1.0.1 [message #58761 is a reply to message #58683] Tue, 03 October 2006 10:30 Go to previous messageGo to next message
Hi Radek,
That's true, I have multiple sections like that in my *.gmfgen file:
<domainInitializer
xsi:type="gmfmap:FeatureSeqInitializer">
<initializers
body="ReaderType::Alien">
<feature
xsi:type="ecore:EAttribute"
href="model.ecore#//Reader/type"/>
</initializers>
<initializers
body="'Reader'">
<feature
href="model.ecore#//Reader/name"/>
</initializers>
</domainInitializer>
Now my question is: how can we initialize two different attributes of
the same element in a map file?
Jerome
Radek Dvorak a écrit :
> Hi Jerome,
> /Radek
Re: Can't regenerate with GMF 1.0.1 [message #58785 is a reply to message #58761] Tue, 03 October 2006 10:40 Go to previous messageGo to next message
Jerome,
You can 'initialize two different attributes of the same element in a map
file'.
But you can not initialize the same attribute multiple times in a single
instance. There always was such a constraint.
Could you post please a corresponding fragment from your gmfgen, which
causes the problems?
/Radek
On Tue, 03 Oct 2006 16:30:43 +0200, Jerome Louvel <contact@noelios.com>
wrote:
> Hi Radek,
> <domainInitializer
> <initializers
> <feature
> </initializers>
> <initializers
> body="'Reader'">
> <feature
> </initializers>
> Jerome
>> Hi Jerome,
>> Regards,
>> /Radek
Can't initialize multiple attributes (Was: Can't regenerate with GMF 1.0.1) [message #58810 is a reply to message #58785] Tue, 03 October 2006 10:52 Go to previous messageGo to next message
Radek,
Ok, this is probably not a 1.0 -> 1.0.1 related issue then. I now
remember that I was adding these extra initializations just before
upgrading: sorry for the confusion.
As for the fragment, the one that I gave in my previous email has the
problem:
- first attribute: "model.ecore#//Reader/type"
- second attribute: "model.ecore#//Reader/name"
Am I missing something obvious?
Jerome
Radek Dvorak wrote :
> Jerome,
> map file'.
> /Radek
> wrote:
>> Hi Radek,
>> <domainInitializer
>> <initializers
>> <feature
>> </initializers>
>> <initializers
>> body="'Reader'">
>> <feature
>> </initializers>
>> Thanks,
>> Jerome
Re: Can't initialize multiple attributes (Was: Can't regenerate with GMF 1.0.1) [message #58887 is a reply to message #58810] Tue, 03 October 2006 11:24 Go to previous messageGo to next message
What I had in mind is a fragment of your gmfgen model as your original =
post contains
'Diagnosis of =
org.eclipse.gmf.codegen.gmfgen.impl.GenEditorGeneratorImpl@1f523a3{platf=
orm:/resource/com.supplyinsight.designer/model/source.gmfgen #Source}'
Your gmfmap part looks OK, so I believe there is some sort of discrepanc=
y =
in the gmfgen.
Or do you get any problem markers also for the .gmfmap model?
/Radek
On Tue, 03 Oct 2006 16:52:31 +0200, Jerome Louvel <contact@noelios.com> =
wrote:
> Radek,
> Ok, this is probably not a 1.0 -> 1.0.1 related issue then. I now =
> remember that I was adding these extra initializations just before =
> As for the fragment, the one that I gave in my previous email has the =
> problem:
> Jerome
>> Jerome,
>> You can 'initialize two different attributes of the same element in=
a =
>> map file'.
>> But you can not initialize the same attribute multiple times in a =
>> single FeatureSeqInitializer
>> Could you post please a corresponding fragment from your gmfgen, whi=
ch =
>> /Radek
>> On Tue, 03 Oct 2006 16:30:43 +0200, Jerome Louvel =
>> <contact@noelios.com> wrote:
>>> Hi Radek,
>>> That's true, I have multiple sections like that in my *.gmfgen file:=
>>> <domainInitializer
>>> xsi:type=3D"gmfmap:FeatureSeqInitializer">
>>> <initializers
>>> body=3D"ReaderType::Alien">
>>> <feature
>>> xsi:type=3D"ecore:EAttribute"
>>> href=3D"model.ecore#//Reader/type"/>
>>> </initializers>
>>> <initializers
>>> body=3D"'Reader'">
>>> <feature
>>> href=3D"model.ecore#//Reader/name"/>
>>> </initializers>
>>> Now my question is: how can we initialize two different attributes o=
f =
>>> Thanks,
>>> Jerome
Re: Can't initialize multiple attributes (Was: Can't regenerate with GMF 1.0.1) [message #58937 is a reply to message #58887] Tue, 03 October 2006 12:14 Go to previous messageGo to next message
I've just sent you by email all my model files to help you isolate the
actual issue.
Jerome
> post contains
> 'Diagnosis of
> org.eclipse.gmf.codegen.gmfgen.impl.GenEditorGeneratorImpl@1f523a3 {platform:/resource/com.supplyinsight.designer/model/source. gmfgen#Source}'
> discrepancy in the gmfgen.
> /Radek
Re: Can't initialize multiple attributes (Was: Can't regenerate with GMF 1.0.1) [message #59593 is a reply to message #58937] Thu, 05 October 2006 10:08 Go to previous message
Jerome, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=159879
"Jerome Louvel" <contact@noelios.com> wrote in message
news:efu288$ok6$1@utils.eclipse.org...
> actual issue.
> Jerome
>> post contains
>> 'Diagnosis of
>> Your gmfmap part looks OK, so I believe there is some sort of discrepancy
>> in the gmfgen.
>> /Radek
Previous Topic:Link appearance
Next Topic:Could there be no scroll pane in compartment?
Current Time: Thu May 08 02:23:47 EDT 2025
Powered by FUDForum. Page generated in 0.05323 seconds
