Home » Modeling » TMF (Xtext) » Conversion from oaw to tmf xtext - Access values of Datatype refs
Conversion from oaw to tmf xtext - Access values of Datatype refs [message #58657] Wed, 15 July 2009 02:44 Go to next message
Another dump question in context of migration regarding to Datatypes:
E.g. we had the following definition in our OAW xtext grammar:
String DataType:("string"|"integer"|"long"|...|"collection");
And changed to
e.g.
Dto :
'dto' name=ID '{'
properties+=DtoProperty*
Property:
'property' name=ID ':' type=[Type] (many?='[]')?;
DtoProperty:
'property' name=ID ':' type=DtoDataType (many?='[]')?;
DtoDataType:("string"|"long"|"integer");
Now we are not able to do a switch case with string on DataType Ref's:
e.g. the following doesn't work anymore
boolean isStringType(EntityAttribute this) :
// this.type points to a DataType
switch (this.type) {
case "string": true
case "text": true
default: false
How can I solve this problem? How can I get the value of a
Is there a documentation how to solve this kind of (common??) problems?
Re: Conversion from oaw to tmf xtext - Access values of Datatype refs [message #58681 is a reply to message #58657] Wed, 15 July 2009 02:51 Go to previous messageGo to next message
Hi Martin,
I'm afraid I'm missing the point of your question. As far as I can see,
there will be no limitation for switch/case statements when you use data
type rules instead of the oAW's string rules.
Consider the following grammar:
Model:
"type" "=" type = Datatype;
Datatype: "string" | "integer";
and this input:
type = string
The meta model for your grammar will be
eClass Model {
eAttribute 'type': String;
As you can see, type is a simple string attribute, thus any operation on
strings can be performed.
Did I get your question wrong? What was your actual problem. I cannot
find an EntityAttribute in your grammar snippet nor do can I find
(cross) references to data types.
Sebastian
Am 15.07.2009 8:44 Uhr, schrieb Martin Kuhn:
> And changed to
> e.g.
> Dto :
> 'dto' name=ID '{'
> Property:
> DtoProperty:
> case "string": true
> case "text": true
> default: false
Re: Conversion from oaw to tmf xtext - Access values of Datatype refs [message #58707 is a reply to message #58681] Wed, 15 July 2009 03:28 Go to previous messageGo to next message
> Hi Martin,
Hi Sebastian,
thanks for answering and sorry for the example which was a little bit
confusing (I took a piece of an existing project).
My point is that I'm not able to access (at least with my knowledge) the
concrete value of a DtoDataType ref (it sounds like a really simple
problem :-( )
Here is a complete example where I try to resolve the concrete type
(DtoDataType im my Template) of a DtoProperty referenced in a Dto. This
means war DtoDataType has a concrete property of my Dto
(string,integer,long) but I'm not able to get the value.
Remark -> the piece of code in the Extension part leads to an error (-> in
the switch block -> DtoDataType expected) which works in OAW xtext and
which we have in use extensively
XText grammar
Model :
(dtos+=Dto)*;
Dto :
'dto' name=ID '{'
DtoProperty:
Model:
dto PersonDto {
property name: string
property age: integer
property salery: long
Template:
«IMPORT entities»;
«EXTENSION templates::Extensions»
«DEFINE main FOR Model-»
«FILE "output.txt"-»
«FOREACH this.dtos AS d-»
DTO «d.name»
«FOREACH d.properties AS p»
«REM»Here I try to resolve the datatype (string,long,integer) -> I
don't know how to get the value «ENDREM»
Property «p.name» Type: «p.type» «p.type.toString()»
«ENDFOREACH»
«ENDFOREACH-»
«ENDFILE-»
«ENDDEFINE»
Extension:
import entities;
String getType(DtoDataType dtoType):
switch(dtoType) {
// THIS is now an ERROR -> DtoDataType expected
case "string": "is a string"
default: "nix wissen"
Re: Conversion from oaw to tmf xtext - Access values of Datatype refs [message #58732 is a reply to message #58707] Wed, 15 July 2009 03:38 Go to previous messageGo to next message
Hi Martin,
there seems to be a problem with the type inference. In your case,
DtoDataType has not been recognized as a data type rule. Could you
please file a bugzilla? Please try something like this instead as a
workaround:
grammar org.xtext.example.MyDsl1 with org.eclipse.xtext.common.Terminals
generate myDsl1 "http://www.xtext.org/example/MyDsl1"
// this line is new
import "http://www.eclipse.org/emf/2002/Ecore"
Model :
(dtos+=Dto)*;
Dto :
'dto' name=ID '{'
DtoProperty:
// the return statement is new
DtoDataType returns EString: ("string"|"long"|"integer");
Sebastian
Am 15.07.2009 9:28 Uhr, schrieb Martin Kuhn:
>> Hi Martin,
>> see, there will be no limitation for switch/case statements when you
>> use data type rules instead of the oAW's string rules.
> Hi Sebastian,
> problem :-( )
> in the switch block -> DtoDataType expected) which works in OAW xtext
> and which we have in use extensively
> XText grammar
> Model :
> (dtos+=Dto)*;
> Dto :
> 'dto' name=ID '{'
> DtoProperty:
> Model:
> dto PersonDto {
> Template:
> «IMPORT entities»;
> DTO «d.name» «FOREACH d.properties AS p»
> «REM»Here I try to resolve the datatype (string,long,integer) -> I don't
> Property «p.name» Type: «p.type» «p.type.toString()» «ENDFOREACH»
> «ENDFOREACH-»
> «ENDFILE-»
> «ENDDEFINE»
> Extension:
> import entities;
> switch(dtoType) {
Re: Conversion from oaw to tmf xtext - Access values of Datatype refs [message #58756 is a reply to message #58732] Wed, 15 July 2009 04:07 Go to previous messageGo to next message
Sebastian,
I changed the def to:
But I'm still not available to get the type in my template (the «p.type»
leads to NO output):
And in my Extension I get the error "EString expected" what it is
understandable but different from OAW behaviour (how can I fix this?)
String getType(DtoProperty dtoProperty):
switch(dtoProperty.type) {
Re: Conversion from oaw to tmf xtext - Access values of Datatype refs [message #58806 is a reply to message #58756] Wed, 15 July 2009 04:39 Go to previous messageGo to next message
Martin,
did you add the import of the ecore meta model, too?
// this line is new
Sebastian
Am 15.07.2009 10:07 Uhr, schrieb Martin Kuhn:
> Sebastian,
Re: Conversion from oaw to tmf xtext - Access values of Datatype refs [message #58880 is a reply to message #58806] Wed, 15 July 2009 05:05 Go to previous messageGo to next message
Sebastian Zarnekow wrote:
> Martin,
> // this line is new
Sebastian,
where do I have to place the import?
When I try to import "http://www.eclipse.org/emf/2002/Ecore" in my model I
get an error "Imported resource can not be found"
Re: Conversion from oaw to tmf xtext - Access values of Datatype refs [message #58929 is a reply to message #58880] Wed, 15 July 2009 05:35 Go to previous messageGo to next message
Hi Martin,
please have a second look at one of my previous answers:
// this line is new
import "http://www.eclipse.org/emf/2002/Ecore" // <-- it is here!!!
Model :
(dtos+=Dto)*;
Dto :
'dto' name=ID '{'
DtoProperty:
Sebastian
Am 15.07.2009 11:05 Uhr, schrieb Martin Kuhn:
>> Martin,
>> // this line is new
> Sebastian,
> I get an error "Imported resource can not be found"
Re: Conversion from oaw to tmf xtext - Access values of Datatype refs [message #58954 is a reply to message #58929] Wed, 15 July 2009 05:47 Go to previous messageGo to next message
Sebastian,
yeah it works. Thank you very much.
Martin
> Hi Martin,
> // this line is new
> Model :
> (dtos+=Dto)*;
> Dto :
> 'dto' name=ID '{'
> DtoProperty:
> Sebastian
>>> Martin,
>>> // this line is new
>> Sebastian,
Re: Conversion from oaw to tmf xtext - Access values of Datatype refs [message #59421 is a reply to message #58732] Thu, 16 July 2009 04:26 Go to previous message
I've entered a corresponding bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=283671
Sebastian Zarnekow schrieb:
> Hi Martin,
> workaround:
> // this line is new
> Model :
> (dtos+=Dto)*;
> Dto :
> 'dto' name=ID '{'
> DtoProperty:
> Sebastian
>>> Hi Martin,
>> Hi Sebastian,
>> problem :-( )
>> XText grammar
>> Model :
>> (dtos+=Dto)*;
>> Dto :
>> 'dto' name=ID '{'
>> DtoProperty:
>> Model:
>> dto PersonDto {
>> Template:
>> «IMPORT entities»;
>> «ENDFOREACH-»
>> «ENDFILE-»
>> «ENDDEFINE»
>> Extension:
>> import entities;
>> switch(dtoType) {
Previous Topic:[XText] Cross Reference - Custom
Next Topic:Using xtext for comprehensive languages
Current Time: Sat Jul 26 13:15:40 EDT 2025
Powered by FUDForum. Page generated in 0.04875 seconds
