Conversion from oaw to tmf xtext - Access values of Datatype refs [message #58657] |
Wed, 15 July 2009 02:44  |
Another dump question in context of migration regarding to Datatypes:
E.g. we had the following definition in our OAW xtext grammar:
String DataType:("string"|"integer"|"long"|...|"collection");
And changed to
e.g.
Dto :
'dto' name=ID '{'
properties+=DtoProperty*
Property:
'property' name=ID ':' type=[Type] (many?='[]')?;
DtoProperty:
'property' name=ID ':' type=DtoDataType (many?='[]')?;
DtoDataType:("string"|"long"|"integer");
Now we are not able to do a switch case with string on DataType Ref's:
e.g. the following doesn't work anymore
boolean isStringType(EntityAttribute this) :
// this.type points to a DataType
switch (this.type) {
case "string": true
case "text": true
default: false
How can I solve this problem? How can I get the value of a
Is there a documentation how to solve this kind of (common??) problems?
Re: Conversion from oaw to tmf xtext - Access values of Datatype refs [message #58732 is a reply to message #58707] |
Wed, 15 July 2009 03:38   |
Hi Martin,
there seems to be a problem with the type inference. In your case,
DtoDataType has not been recognized as a data type rule. Could you
please file a bugzilla? Please try something like this instead as a
workaround:
grammar org.xtext.example.MyDsl1 with org.eclipse.xtext.common.Terminals
generate myDsl1 "http://www.xtext.org/example/MyDsl1"
// this line is new
import "http://www.eclipse.org/emf/2002/Ecore"
Model :
(dtos+=Dto)*;
Dto :
'dto' name=ID '{'
DtoProperty:
// the return statement is new
DtoDataType returns EString: ("string"|"long"|"integer");
Sebastian
Am 15.07.2009 9:28 Uhr, schrieb Martin Kuhn:
>> Hi Martin,
>> I'm afraid I'm missing the point of your question. As far as I can
>> see, there will be no limitation for switch/case statements when you
>> use data type rules instead of the oAW's string rules.
> Hi Sebastian,
> thanks for answering and sorry for the example which was a little bit
> confusing (I took a piece of an existing project).
> My point is that I'm not able to access (at least with my knowledge) the
> concrete value of a DtoDataType ref (it sounds like a really simple
> problem :-( )
> Here is a complete example where I try to resolve the concrete type
> (DtoDataType im my Template) of a DtoProperty referenced in a Dto. This
> means war DtoDataType has a concrete property of my Dto
> (string,integer,long) but I'm not able to get the value.
> Remark -> the piece of code in the Extension part leads to an error (->
> in the switch block -> DtoDataType expected) which works in OAW xtext
> and which we have in use extensively
> XText grammar
> Model :
> (dtos+=Dto)*;
> Dto :
> 'dto' name=ID '{'
> DtoProperty:
> Model:
> dto PersonDto {
> property name: string
> property age: integer
> property salery: long
> Template:
> «IMPORT entities»;
> «EXTENSION templates::Extensions»
> «DEFINE main FOR Model-»
> «FILE "output.txt"-»
> «FOREACH this.dtos AS d-»
> DTO «d.name» «FOREACH d.properties AS p»
> «REM»Here I try to resolve the datatype (string,long,integer) -> I don't
> know how to get the value «ENDREM»
> Property «p.name» Type: «p.type» «p.type.toString()» «ENDFOREACH»
> «ENDFOREACH-»
> «ENDFILE-»
> «ENDDEFINE»
> Extension:
> import entities;
> String getType(DtoDataType dtoType):
> switch(dtoType) {
> // THIS is now an ERROR -> DtoDataType expected
> case "string": "is a string"
> default: "nix wissen"
Re: Conversion from oaw to tmf xtext - Access values of Datatype refs [message #59421 is a reply to message #58732] |
Thu, 16 July 2009 04:26  |
I've entered a corresponding bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=283671
Sebastian Zarnekow schrieb:
> Hi Martin,
> workaround:
> // this line is new
> Model :
> (dtos+=Dto)*;
> Dto :
> 'dto' name=ID '{'
> DtoProperty:
> Sebastian
>>> Hi Martin,
>> Hi Sebastian,
>> problem :-( )
>> XText grammar
>> Model :
>> (dtos+=Dto)*;
>> Dto :
>> 'dto' name=ID '{'
>> DtoProperty:
>> Model:
>> dto PersonDto {
>> Template:
>> «IMPORT entities»;
>> «ENDFOREACH-»
>> «ENDFILE-»
>> «ENDDEFINE»
>> Extension:
>> import entities;
>> switch(dtoType) {
FUDForum. Page generated in 0.04419 seconds
