Global Options? [message #58617] |
Wed, 27 April 2005 18:35 |
Originally posted by: jeroen.lightyear.be
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
When i first started using Eclipse i thought there were three levels to
set options and that every lower level inherits and overrides the
settings of the upper level:
Global Level
| Inherits, overrides
v
Workspace level
| Inhertis, overrides
v
Project level
This seemed logical to me because it would enable one to set options in
such a way that they would be always the same for every workspace and
still have the possibility to change settings specific for one workspace
or even one project
However now that i have been working with Eclipse on some real projects
i discovered there is no 'global level' for options. This means that
- - every time i create a new workspace i'm welcomed with the default
settings again, and first have to start customizing it to have /my/
default settings in that workspace.
- - When i change a setting in one workspace (by example for a new plugin
i installed) i have to change it manually in all my other workspaces too.
So my question is:
- - Am i right on this? Is there really no global level? Or did i miss
something?
- - How do other people sync there 'global' settings between their
different workspaces? i'm sure i'm not the only one who has this problem?
I was thinking of making a 'default workspace' with all my
customizations so that i could clone that one whenever i want to create
a new workspace. But this wouldn't work for new/changed settings which i
want to apply to already existing workspaces.
Then i started thinking about putting my 'default workspace' under
source control (darcs would do well i think, http://darcs.net) so that i
would be able to change my settings in my 'default workspace' and then
sync my in-use workspaces with my 'default workspace' (from the repository).
Would this be an option?
Thx!
Greetz,
Jeroen
<TeRanEX/>
--- e-mail: jeroen@lightyear.be - jid: teranex@jabber.org
--- blog: http://budts.be/weblog/ - cv: http://budts.be/jeroen/
--- projects: http://lightyear.be - pgp: 0x8B7B774A
_____________________________________
NO SoftwarePatents in Europe!
See an example: http://webshop.ffii.org/
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFCcBPJH04wF4t7d0oRAkn8AJ4x9eHXtfsIm3qRizbSffmSdhTJDACe NRFg
L3IA3zvk1YGOqYk8hf2ojjU=
=XvPZ
-----END PGP SIGNATURE-----
FUDForum. Page generated in 0.36671 seconds
