Re: [buckminster-dev] help with CVS [message #5233] |
Thu, 21 February 2008 15:50 |
Hi Todd,
By all means, enter a bugzilla. We will resolve this one way or another.
I'm more or less a CVS server illiterate and I have always thought that
the server concealed the actual physical location of folders on disk,
whether or not they were symlinked etc. The CVSNT server I use does that
(there's a 'location' which is the physical location on disc and a
'name' which is the cvsroot as it appears to the clients). Apparently,
Linux/Unix systems work differently.
Thanks Todd for spending time tracking this down.
Thomas Hallgren
Todd_Lee@amis.com wrote:
> Okay, so just to follow up on-list with the cause/resolution for this (in
> case anyone besides myself has worn a hole in their desk from banging their
> head :) ) With Thomas' help we were able to determine that the cvs provider
> (reader) built into buckminster does not support CVS repositories whose
> CVSROOT contains symbolic links.
> ie -
> physical absolute path:
> /path/to/cvsroot
> path used externally:
> /path/to/cvsroot/with/symlink -> /path/to/cvsroot
> As a result, the provider will fail to get metadata for any files in the
> repository, making for an unsuccessful resolution. The reason is that,
> while the the provider uses the external path in the rmap, when collecting
> metadata it gets the file location (physical absolute path) from the RCS
> file info gathered via the 'rlog' request. A validation check that matches
> the file paths fails, causing the file to be skipped - ignoring its
> metadata.
> As a workaround, CVS can be reconfigured to add the additional path as an
> alias for the CVSROOT (which we've done) but I wonder if this should be
> entered as a bugzilla issue to be handled inside Buckminster?
> Todd
> Todd_Lee@amis.com
> Sent by:
> buckminster-dev-b To
> ounces@eclipse.or Buckminster developer discussions
> g <buckminster-dev@eclipse.org>
> cc
> 02/15/2008 09:07 Subject
> AM Re: [buckminster-dev] help with CVS
> Please respond to
> Buckminster
> developer
> discussions
> <buckminster-dev@
> eclipse.org>
> Hi Thomas,
> Thanks again for all your help in trying to get us up and running...
> I'm actually working from home today, so I'm on our vpn and I just grabbed
> the latest buckminster from the update site.
> I was able to successfully run your public cquery and everything
> resolved/materialized without incident.
> Feeling bold, I tried the same helloworld test that I set up on our local
> cvs yesterday and I still got the same error. I'm left scratching my head!?
> Oh, and so as not to create any wild goose chases, I did find docs last
> night that confirmed that eclipse cvs should be fine with cvs going all the
> way back to 1.11.1, so I'm assuming our 1.11.3 shouldn't be a problem.
> If you have any other suggestions, please feel free to fire them off.
> One question - is there any way to get more debug info out of the
> resolution stage? I have all three log settings in the prefs set to full
> DEBUG and there's still not a whole lot of information in the console or
> the .metadata/.log file.
> It would probably be helpful if the debug statements actually printed out
> checks for the files inside the cvs path that buckminster uses to poll for
> metadata for a given component type. Could give us a better idea of where
> it's failing?
> Thanks
> Todd
> Todd Lee
> Software Tools
> AMI Semiconductor
> Tel: +1.519.884.9696 ext 2242
> Fax: +1.519.884.0228
> E-mail: todd_lee@amis.com
> -----buckminster-dev-bounces@eclipse.org wrote: -----
> To: Buckminster developer discussions <buckminster-dev@eclipse.org>
> From: Thomas Hallgren <thomas@tada.se>
> Sent by: buckminster-dev-bounces@eclipse.org
> Date: 02/15/2008 05:06AM
> Subject: Re: [buckminster-dev] help with CVS
> Hi Todd,
> > Thanks for the effort - sorry to report it's a no go...
> > After spinning it's wheels for a while (pressed resolve to wizard) I get
> a
> > dialog popup the details of which are:
> > "Could not connect to
> :pserver:anonymous@www.tada.se:/cvsroot/test:
> > I/O has been interrupted.
> > Timeout while reading from input stream"
> A difficult one to crack, this is...
> Last night I tried using machines that were on the same LAN as the CVSNT
> server. So today I tried
> running the resolution from one machine in our office in Pilsen Czech
> Republic (running Vista) and
> another machine here in Sweden (running Linux). No luck. I just can't
> provoke this error. It works
> like a charm every time.
> I made the cquery public. You can find it here:
> http://www.tada.se/pub/queries/demo.cquery
> This query contains relative URL's so it will really require the latest
> version of Buckminster.
> - thomas
> _______________________________________________
> buckminster-dev mailing list
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
> AMI Semiconductor - "Silicon Solutions for the Real World"
> NOTICE:
> This electronic message contains information that may be confidential or
> privileged. The information is intended for the use of the individual or
> entity named above. If you are not the intended recipient, please be aware
> that any disclosure, copying, distribution or use of the contents of this
> information is prohibited. If you received this electronic message in
> error, please notify the sender and delete the copy you received.
> NOTICE:
> This electronic message contains information that may be confidential or privileged. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of the contents of this information is prohibited. If you received this electronic message in error, please notify the sender and delete the copy you received.
FUDForum. Page generated in 0.03276 seconds
