Home » Language IDEs » Java Development Tools (JDT) » Using SOAP
Using SOAP [message #58553] Mon, 16 June 2003 11:23 Go to next message
Hi All,
I was wondering whether we have any inbuilt API for using SOAP. im
developing a plugin fpr Eclipse 2.0/WSAD v5.0. The plugin needs to get
data from one of the servers. Has anyone done something like this
before(am sure somebody has already attempted to do this.).i did a search
for SOAP but didnt find much of help there. Is there any API like SAAJ or
anything else.
ANyt helpis greatly appreciated.
thanx
AJ
ajayinfo@rediffmail.com
Re: Using SOAP [message #58994 is a reply to message #58553] Tue, 17 June 2003 04:19 Go to previous messageGo to next message
> anything else.
You can use Apache AXIS or Glue from The Mindelectrics for generating
the SOAP stubs.
http://ws.apache.org/axis
http://www.themindelectric.com/glue/
HTH,
Frank
Re: Using SOAP [message #59308 is a reply to message #58994] Tue, 17 June 2003 11:57 Go to previous messageGo to next message
Hi Frank,
Thanx for youyr response. I did check out Axis and Glue. Both of them are
heavy weight API's. Do we have any plugins readily available which u can
use directly within Eclipse.
thanx
AJay
Frank Fischer wrote:
> > anything else.
> the SOAP stubs.
> HTH,
> Frank
Re: Using SOAP [message #59358 is a reply to message #59308] Tue, 17 June 2003 12:07 Go to previous messageGo to next message
Originally posted by: Kevin.clark.accessbc.com.nospam
This may be what you are looking for:
http://eclipse-plugins.2y.net/eclipse/plugin_details.jsp?id= 347
That's about the only SOAP program I know about that is a plug-in for
eclipse.
AJay wrote:
> Hi Frank,
> thanx
> AJay
> > Hi,
> > > anything else.
> > the SOAP stubs.
> > HTH,
> > Frank
Re: Using SOAP [message #60037 is a reply to message #59308] Wed, 18 June 2003 03:22 Go to previous message
> thanx
If you want to use your eclipse plugin as a webservice client only,
then you have to generate the stubs for the target webservice by using
the wsdl2java tool.
The generated stubs are very easy to use.
<sample src="AXIS User Guide">
// Make a service
AddressBookService service = new AddressBookServiceLocator();
// Now use the service to get a stub which implements the SDI.
AddressBook port = service.getAddressBook();
// Make the actual call
Address address = new Address(...);
port.addEntry("Russell Butek", address);
</sample>
Thats it.
BTW:
Do you really need SOAP or do you just need some kind of XML communication?
Maybe XML-RPC can solve your problem.
http://www.xmlrpc.org/
http://ws.apache.org/xmlrpc/
HTH,
Frank
Previous Topic:Unknown warnings
Next Topic:color scheme for java editor
Current Time: Sun Nov 16 23:33:14 EST 2025
Powered by FUDForum. Page generated in 0.04279 seconds
