Home » Newcomers » Newcomers » SWT with Visual Editor
SWT with Visual Editor [message #58535] Wed, 27 April 2005 15:02 Go to next message
Originally posted by: esirko.sw-sol.com
Can someone confirm for me that the Visual Editor cannot be used to develop
SWT applications?
Thanks.
Re: SWT with Visual Editor [message #58571 is a reply to message #58535] Wed, 27 April 2005 17:04 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
> SWT applications?
> Thanks.
This is incorrect. The Visual Editor supports development of SWT
applications. The next release will also support development of RCP
applications.
Hope this helps,
- Jeff
Re: SWT with Visual Editor [message #58642 is a reply to message #58571] Wed, 27 April 2005 19:01 Go to previous messageGo to next message
"Jeff Myers" <myersj@gmail.com> wrote in message
news:d4ouv9$51b$1@news.eclipse.org...
>> develop SWT applications?
>> Thanks.
> applications.
> Hope this helps,
> - Jeff
Well, the palette contains plenty of AWT and Swing controls, but nada in the
way of SWT. How does this SWT support manifest itself?
Eric
Re: SWT with Visual Editor [message #58738 is a reply to message #58642] Wed, 27 April 2005 21:54 Go to previous messageGo to next message
> Eric
In the New Visual Class wizard, select a class in the SWT group as the
starting point, or bring up the properties of your Java project, select
the Java Build Path page, the Libraries tab, hit Add Library... and
select SWT Library. The SWT palette options only show up when the SWT
Library is added to the project. Selecting a SWT starting point in the
New Visual Class wizard will do this for you.
Hope this helps,
- Jeff
Re: SWT with Visual Editor [message #59063 is a reply to message #58738] Thu, 28 April 2005 10:45 Go to previous message
"Jeff Myers" <myersj@nospam.gmail.com> wrote in message
news:d4pfqp$lot$1@news.eclipse.org...
>> the way of SWT. How does this SWT support manifest itself?
>> Eric
> the Java Build Path page, the Libraries tab, hit Add Library... and select
> SWT Library. The SWT palette options only show up when the SWT Library is
> added to the project. Selecting a SWT starting point in the New Visual
> Hope this helps,
> - Jeff
Hey you're right. I had added the SWT jar file using the Add JARs button
instead of the Add Library button. Apparently that wasn't good enough.
Thanks!
Previous Topic:troubles with first launch of eclipse
Next Topic:Can't build helloworld.java on eclipse 3.02
Current Time: Sun Jul 13 20:14:33 EDT 2025
Powered by FUDForum. Page generated in 0.17253 seconds
