Home » Newcomers » Newcomers » Using Eclipse for Linux with a remote Samba Share
Using Eclipse for Linux with a remote Samba Share [message #58509] Wed, 27 April 2005 12:33 Go to next message
Originally posted by: gamito.gmail.com
I've used to use Eclipse for Windows and work directly on the Linux web
server files, through a Samba share.
Now that i've switched to Eclipse for Linux i can't see how can i do this.
When i choose a New Project, everything i insert in Project Contents
Directory textbox is not recognized by Eclipse.
Samba is working fine, since in Konqueror, if i insert
smb://vhosts@xxx.xxx.xxx.xxx/cv
i immediatly see the files on the web server.
However, this doesn't works in Eclipse.
Does anyone knows if it's possible to use Ecplise for Linux working
directly on a remote server using Samba ?
If so, how ?
Any help would be apreciated.
Warm Regards,
Mario Gamito
Re: Using Eclipse for Linux with a remote Samba Share [message #58519 is a reply to message #58509] Wed, 27 April 2005 13:29 Go to previous message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
I would mount the smb share as a local directory in my filesystem. That
way, Eclipse treats your SMB share as it would any other directory.
Look at the smbmount command for this.
As an alternative, if your server and client are on a trusted and
relatively secure network, you could use NFS instead of Samba.
D.
Mario Gamito wrote:
> If so, how ?
> Warm Regards,
> Mario Gamito
Previous Topic:editor block mode select, copy, paste supported?
Next Topic:Newbie - JAR Export Difficulties
Current Time: Wed Nov 19 00:01:38 EST 2025
Powered by FUDForum. Page generated in 0.06508 seconds
