how to create several elements and connections in between in single a Command [message #58472] |
Mon, 02 October 2006 22:36  |
Originally posted by: vcciubot.uwaterloo.ca
Hi all,
In my model, if a connection traverses structural hierarchies then it must
be broken down into sub-segments that begin and end on the frontiers of
the spanned elements.
One solution would be to configure the created connection to create the
intermediary elements and subsegments, but in this case an inconsistent
connection will still get created.
I need another approach, but I don't know how to create connections
between non existing edit parts. Is there some example code I should look
at?
thank you
Vlad
Re: how to create several elements and connections in between in single a Command [message #59010 is a reply to message #58472] |
Tue, 03 October 2006 19:36  |
Solved my problem by modifying GraphicalNodeEditPolicy to use the model
only and rely on CanonicalConnectionEditPolicy to create the view elements.
On Mon, 02 Oct 2006 22:36:17 -0400, Vlad Ciubotariu wrote:
> Hi all,
> at?
> thank you
> Vlad
FUDForum. Page generated in 1.29633 seconds
