Home » Eclipse Projects » SWTBot » log4j warnings
log4j warnings [message #5220] Tue, 02 December 2008 17:56 Go to next message
I just created some dummy SWTBotTestCases to check out. So far SWTBot
looks very promising for testing our Eclipse based application.
I noticed in the Eclipse Console View that there are some log4j
warnings. Not being familiar with log4j yet, is this something that
SWTBot should resolve or something that I may need to correct in my
Eclipse installation?
The warnings:
log4j:WARN No appenders could be found for logger
(net.sf.swtbot.matcher.AbstractMatcher).
log4j:WARN Please initialize the log4j system properly.
Joe
Re: log4j warnings [message #5285 is a reply to message #5220] Tue, 02 December 2008 22:22 Go to previous messageGo to next message
This happens when log4j can't find a log.xml.
See http://swtbot.sourceforge.net/faq.html#logging for info on how to
fix this.
On 3/12/08 04:26, Joe Luebker wrote:
> The warnings:
> Joe
Re: log4j warnings [message #6053 is a reply to message #5285] Wed, 03 December 2008 12:11 Go to previous messageGo to next message
> fix this.
>> The warnings:
>> Thanks,
>> Joe
Thanks for pointing me to the faq Ketan. Adding the logging xml file
corrected the warnings. I am encountering some IllegalArgumentExceptions
related to the logging now. I will add another posting for that issue.
Joe
Re: log4j warnings [message #506791 is a reply to message #6053] Sat, 09 January 2010 21:53 Go to previous message
I struggled with this a bit, so in case this can help someone in the future... if your tests are declared in plugin fragments hosted in the tested plugin, you need to put the "Eclipse-Buddy" declaration in the plugin's MANIFEST; it seems that putting it in the fragment's manifest doesn't make a difference.
franck102
Previous Topic:headless swtbot does not find testproject
Next Topic:releaseDate
Current Time: Mon Jul 14 10:38:13 EDT 2025
Powered by FUDForum. Page generated in 0.14674 seconds
