Home » Archived » BIRT » BIRT without plugins?
BIRT without plugins? [message #58407] Thu, 14 July 2005 12:45 Go to next message
Originally posted by: CyberReefGuru**n.o_s.p.a.m**.hotmail.com
I'm trying to run BIRT within my application as an embedded
report engine. I have integrated BIRT using the sample
application, but it relies on the plugin directory
being defined. I've run through the source code and the
report engine make heavy use of the platform infrastructure.
Can I use BIRT WITHOUT eclipse plugins? If not, is there
any possibility of a "light weight" engine that's not so
tightly coupled to eclipse?
-Tom
Re: BIRT without plugins? [message #58966 is a reply to message #58407] Fri, 15 July 2005 07:43 Go to previous messageGo to next message
Originally posted by: csetera.spss.com
Tom,
This is exactly the opposite of what I'd like to see happen (and have
written a bug report to that effect). As it stands right now, BIRT has
their own somewhat inconsistent version of the plugin infrastructure for
use in a server environment. The problem is that it is inconsistent
with the Eclipse plugin model in some ways, making things confusing at
best. I would like to see BIRT running on top of the base Eclipse
plugin infrastructure (OSGI) with no changes.
I'm not sure why you consider this "heavy weight". In reality, I don't
see running as a set of plugins any more heavy than the tons of jar
files that are usually required to run any web application. The
architecture is different, but I would contend that it is really no more
heavy. In order for BIRT to run on the base infrastructure it would
only require a very small number of base plugins (5 or so?) which would
end up being a very small amount of code.
Just my two cents...
Craig
> -Tom
Re: BIRT without plugins? [message #59319 is a reply to message #58966] Sun, 17 July 2005 11:57 Go to previous messageGo to next message
Originally posted by: myname(with.between names).lombardisoftware.com
Although OSGI on the server side is a nice thought, I would think it does
have some issues. My biggest one is the amount of classloaders OSGI creates
and some J2EE application servers might have an issue with that. But I'm
sure there are others. But I haven't looked much at it I'm waiting for the
3.1 release :)
On the client this should be a less of an issue; mostly a company (or
person) wrote the whole environment (unless they use Eclipse) and can
therefore [simply] embed the OSGI framework as well and use plug-ins.
Besides, if you absolutely cannot use OSGI in your client, just use
JasperReports or another already existing Open Source reporting tool.
Craig Setera wrote:
> Tom,
> Craig
>> -Tom
Re: BIRT without plugins? [message #60527 is a reply to message #58966] Thu, 21 July 2005 13:35 Go to previous messageGo to next message
For a server, 11MB is nothing really, but I'd like to use BIRT in a non-
server environment. Right now BIRT encompasses about 11MB of jar files.
Since out app is about 1.5MB, I can't justify adding BIRT just for
reporting.
I've investigated some of the other open source reporting tools, but
really like the eclipse-based report building tool that BIRT offers.
So, I'd like to see a small 500K jar file to generate simple reports.
Just a suggestion.
-Tom
(I do agree about the architecture being somewhat protracted though)
In article <db87hr$17m$1@news.eclipse.org>, csetera@spss.com says...
> Tom,
> Craig
> > -Tom
Re: BIRT without plugins? [message #61189 is a reply to message #59319] Fri, 22 July 2005 13:11 Go to previous message
For those that are interested, I've created a platform bug report
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=104643) to track this issue.
> 3.1 release :)
Previous Topic:solved problems running birt for the first time
Next Topic:Report Templates?
Current Time: Sun Jul 13 01:27:25 EDT 2025
Powered by FUDForum. Page generated in 0.04980 seconds
