distributing org.eclipse.swt.ole.win32 jar file. [message #58370] |
Fri, 03 April 2009 03:32  |
org.eclipse.swt.ole.win32 has a bug.
[OLE] OLE components w/o visual representation The fix is available, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=68194
My plugins have dependancy on this fix.I asked the developer about when
this fix will be released.He told me that there is no such plan as per now.
So I am planning to use the patch locally and destribute the recompiled
jar file with my project specific jar files.
Can anyone guide me if I am authorised to destibute
org.eclipse.swt.ole.win32 jar file along with my installer.
-Padam
Re: distributing org.eclipse.swt.ole.win32 jar file. [message #58514 is a reply to message #58505] |
Fri, 10 April 2009 07:55   |
Padam,
Note that I'm not a lawyer so nothing I say is legal advice. More
comments below.
padamev297 wrote:
> Thanks Ed,
> I have few more doubts, :)
> in the org.eclipse.swt.ole.win32 jar file, i have made three changes.
> A)Change one: which is a fix for bug
> as it is allready available on the bugjilla, i can directly use it.right?
Yes and the source is publicly available already...
> B)Change second: which is a fix for
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=10977
> its not available on bugjilla , I am going to put the fix there.
That will be appreciated. :-)
> C)Change third: this one is interesting here I have to make one of
> the API from this jar file as public so that I can use it from outside.
That's a trivial uninteresting change. Your one statement here
describes it entirely.
> For changes 1 and 2 , as far I understand putting the changes on
> bugjilla will be sufficient.
Yes.
> But as change 3 is not for any bug and is there so that i can access
> the API.
> So I am not sure about what to do to include this type of changes.
I see your point.
> Do i have permission to include changes(like 3 here).?
Absolutely you can change anything your heart might desire. The change
is so trivial, almost like adding a single newline to a file, so I
imagine you could not worry about it at all. To be more precise though,
you could just describe this tiny delta somewhere in the readme of your
distro.
> Also as my project's plugins make use of this jar file , like calling
> API from this jar file. So do i need to make my source files open as well?
No. The source you write from scratch is your own. EPL is not viral
and does not infect your own non-derivative creations.
> padam
FUDForum. Page generated in 0.04699 seconds
