Home » Eclipse Projects » Nebula » Strange resizing behaviour of CollapsibleButtons
Strange resizing behaviour of CollapsibleButtons [message #58364] Tue, 26 August 2008 12:38 Go to next message
Originally posted by: mario.winterer.gmx.net
I've currently started the ButtonsTester example shipped with the
CollapsibleButtons binaries and I'm wondering if the shown resizing
behaviours are bugs, on purpose and if yes, how they can be changed.
It is possible to resize the sash form (via the sash that is some pixels
above the CollapsibleButtons control) as well as the CollapsibleButtons
control itself using the dotted bar at its top. While resizing the sash
form does not shrink the buttons control as expected, resizing the
buttons control itself does so but leaves behind a grey gap between the
sash of the sashform and the (resized) control below.
Is it possible to use just the CollapsibleButtons' resize bar similar to
the sash in the sash form? I'm thinking of the way it is done in MS
Outlook.
There are some other strange behaviours I've noticed which are difficult
to describe. It seems, the control is not really applicable in a
production environment. (I've downloaded the 1.0 nightly build binaries
- maybe there is a stable version somewhere?)
Mario
Re: Strange resizing behaviour of CollapsibleButtons [message #58389 is a reply to message #58364] Wed, 27 August 2008 15:16 Go to previous messageGo to next message
Hello Mario.
Usually half of the issues I receive with the CollapsibleButton widget are
related to the fact that it's a quite difficult widget to get "into a
corner" where it behaves normally.
So, because of that, It would help me a lot if you have a snippet I could
run that reproduces the issues you are describing, so I can see if it's a
widget issue or a layout issue.
Emil
"Mario Winterer" <mario.winterer@gmx.net> wrote in message
news:g91bha$ahr$1@build.eclipse.org...
> form does not shrink the buttons control as expected, resizing the buttons
> control itself does so but leaves behind a grey gap between the sash of
> Outlook.
> production environment. (I've downloaded the 1.0 nightly build binaries -
> Mario
Re: Strange resizing behaviour of CollapsibleButtons [message #58534 is a reply to message #58389] Fri, 29 August 2008 09:10 Go to previous messageGo to next message
Hi Emil.
I'm using the ButtonsTester-code snippet that is part of the
CollapsibleButtonWidget source download. Without any changes it does not
work properly.
Mario
Emil Crumhorn schrieb:
> Hello Mario.
> Emil
>> Outlook.
>> Thanks,
>> Mario
Re: Strange resizing behaviour of CollapsibleButtons [message #58558 is a reply to message #58534] Fri, 29 August 2008 12:04 Go to previous messageGo to next message
--------------020908000302070109020904
Here you've got a screensot of the TestButtons example that was made
after I've moved the widget's dottet bar downwards (attachment!).
Mario Winterer schrieb:
> Hi Emil.
> work properly.
> Mario
>> Hello Mario.
>> are related to the fact that it's a quite difficult widget to get
>> "into a corner" where it behaves normally.
>> could run that reproduces the issues you are describing, so I can see
>> if it's a widget issue or a layout issue.
>> Regards,
>> Emil
>>> pixels above the CollapsibleButtons control) as well as the
>>> CollapsibleButtons control itself using the dotted bar at its top.
>>> While resizing the sash form does not shrink the buttons control as
>>> expected, resizing the buttons control itself does so but leaves
>>> behind a grey gap between the sash of the sashform and the (resized)
>>> control below.
>>> to the sash in the sash form? I'm thinking of the way it is done in
>>> MS Outlook.
>>> difficult to describe. It seems, the control is not really applicable
>>> in a production environment. (I've downloaded the 1.0 nightly build
>>> binaries - maybe there is a stable version somewhere?)
>>> Thanks,
>>> Mario
Content-Type: image/png;
name="CollapsibleButtonsCollapsed.png"
Content-Disposition: inline;
filename="CollapsibleButtonsCollapsed.png"
iVBORw0KGgoAAAANSUhEUgAAAMgAAAGQCAIAAABkkLjnAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
JD5JREFUeF7tnQl8VNW9x28SsunDp0R5UBBEFhHZAihLCPsOwQQIsoYAJiQB gizKIgLq81kt
VGhtfdLWyrNPKopWW2pRRK0+ShVNCIIJhGadmSxsSWYLBPL+Z87k5uYmN4SZ OZNM7i+f/2c4
99xz/uec3/ne/90vfhdLcyQ/SaqW+G9Y/CU/vwCJkteC6VcKoFzHX1AISwcH SG0CpKrr9OsX
EFB9vVqquiH5+0v+knTDWVCqooWW88fG0vx/flebvw+8B9VKQSh9vU7HKvkS 9TZIulolBTkm
9aq/FNSG5UlVzK45kAgkYto4CreRrlVLlUXf/tRYxxWBdfFCDv36zUgnC1ph Dl53PWxL9U+e
Y9b9heoHdlWH76wOf7V6xB5mkb9iNvo1TeMFWog10k9vrmohajQ4d5TJp1X+ 5RNd3xgGdY3w
ICNaglZVSaMzpPBj1TV/0oWSbDJCyn9xMVHlv6oseMMNKiqz1e2lajLC66Hd tUaccVNmIt3y
FaB55Ma7ytOcDx5E+HTLRpnKRR5uZOOckAWvuU4mzauQIjI4Wgwsaew3UnS+ NPusX0IpmbTi
IjeCLCDVErDmKqEmrb8esK6ajKfpV87kCZ4ZtPYGBTxeEiYr4LfqRgsx6hL1 hM8mnzVufilX
/RMqA5LMAQllfvEWaUm5tMDxu7CcFp058ZckbosusF9aG1sizStlRjlkcwqk 8aekyGwGVknJ
WQbW9O+kBTm1FmeSlhVzyAgvbgwyDWNrqU+yJZRR/2C+ocDyCwFkS0v9lpbQ XotMWmCS5hmZ
xRqcRsRwm53HLDqXzC8qW5pGlilN/pEZJYiqod9KHd5lYEmDvmSrCazZZ53G CXOwJePlDGPJ
5ZJsNYGNVjEElThzfluEFUuLYHUVIG5Uxhmqx00NOjUAETrcOEmEERkdWkWe cBpRRTiR3fOm
Ayyysd/QYZYWWHwXqdxLcphYDgW2pSVSXDEzmkLeY8477GYKBC4wJP661HDx mnzM28QE1aK6
XGHXnbxaGjjXEYei8wNn5SbuMRku3HpPXswJjDjBAlX4MQZSn4+lXu85wOrx dkNgFSojlgyW
DJOCJxMrKW8BqhAqx9LmSsgxvHkTfA9SzxJ/WZxtuL5+rz1+py32P61R26xT tljGPWWZsMky
aj2ziLXMBq8ykw1MMfd+3Nx18eUhK3IzzpVTXe7QXSd0eB3NqLqal136s/XF T8eb1sYaU6IM
iVMKl44rXD6hcMkosoJFEWT5cwczmz0wN6p39sSu6bOHXM7MSHwxh1HFwbr/ MCPqjmck2iOy
5cgT/hOVEYuBxUIRD0iO4y1mS0tqM5UhShmlmncKW2brGmBRfHrqt/bdH1S+ +lHlC/vtT/7W
nvqaPekXtsTdtmU/ty3ZaYv7mW3+T61zX7BGP2edutUy+knLoJXl3RcVDFz0 fxRdOFjuOnEc
MJGTC7ueuvzW7itvv3pp7wulu54seTG15Nmk4u2JxVuXFW1eUrQ5rujJ+aZ1 c42p0YakqYXx
o3NjB6VP6v7X6QMNJVedEavv8QbAYntNOsxakHPbptP3bM/+ty3nQjefC9l8 ru3T2XdszW73
zLnbNp8N2XRWWpcZtPGstD5TetokJWY2sPtrruDUYLsthDNtsBJ22177S+Xe j6++dKByy5v2
dXvtq39FbNkTXmFsLd1lW/yybf6L1lnPW2dss47faBmaWt57ScE9kw6zA+Qa sNxyQmBNZ2AV
b0+48s5rZe/tvfS7ly7s2VL6s3UlL6wufjapaFsCsVX89NKijYuLNsw3rpll SJlRuHx83vyh
GdN6Hxh8D+sJ7QrJCKz7jisiFgUxOgSjgzJqg2Zi5bfSypNSarq0+mTAuozA tZQ+Ka1OY79r
0sa8ZpBS0ib8j/V6Sn9alB79ts5xVYuiqsV3hqZk3n9ZCaldByu3v2Vf+7o9 5Zf2x39uiyOY
/ss25zlrzA7r9K2WaVvZzpHC1Yh15iGryvssLegw5VM2nY4BuuskqoCDVbRh HiF1ed+ui7/a
Xvry2pLnU4qfebxoU5xp/XzTmjnG1TGGpOmGpGls5xg/umDRiNy5QzJm9Hnv kQ6sJ49kMONg
0TGWc1dYF6zvc7IPZ2QdPnX2cMZZ9sssi+XQYkbWX9MyPz6Z9Ze0zAMZBUN3 /SDNPA6wak/L
bxFlmpJZz1k3/96+dR+jasUeezzt+16wzX7WGvW0ddJGy9j1lhFrzMNSiSfz oFXm8JXmgcll
fZcV3jvjiBIspZObHv6rndSAZVoz68KezRd+uZWosp34O/kxrZtvWj3bkBRV +PikwiVjCxaO
KJg/jPIrPj2YHxueM3vgqZl9D464VwOsnxxhQSyCIlY2C62OLaC6+moTrHrZ W/kqsJSjumK5
np5z1WXRPVuROkN9S9p7mdzSrypNa3lzxVeqyOo3nVd6zX71hutdijFIDRl1 gw7Y6bjqCUes
WrbTvpAC1Q4bUTV5o3XMOqLKMmS1eeBKc79kc99kS79kS//k8r7LDU6wHD5V Tm4KltpJDVh0
wF76Ymrpy09QrJKdOKiaXLhkDFGVP3eInJ8/q1/OrP6nohoCy3nwTmBREBvj uFZB+0EnWJXV
1WQqvOQcmqQb1EbC/+T4x3wjzS9y2jwjb/i2Ds+THfoki9L5RfbG5+MfWZXy vFJJ1aLrc1k3
eBDi1Jk3/vB9m5icvUfMqnTGD0WhA9/lYJVctIc+/JGqXT6u0D5veqo/8l5s 0mYLHVERVQmv
2ONesj32vC16m3XaZuv4Jy2Ray2PpJoHrLQ8lGzpvcLyQKKlT5Klb3J5n2WF nWd8poxYSic3
BUvtpAYsQ8IkOqJie8BtCUUb42Q/hUvHFy6OLJj3SC1VMx/Ij+6TG9P3VFSf g8M7s54My2QU
PZiu2BUqwaItoBasqupquqrRSOiqTnrjXEDMdwGL6VpoMWdLBksWjnJChh9u ZD6cc+aY15rW
q/k0e9D2f22lhj7/Kido+pnPTtlV6QMf/BAy5iveHFGlBRZtLR7sEh8sMUHX GpbtYjvBhS/S
cZVt5lbr5E3WsRssI9ZahqSa+6209E629FhhuT/R0nOF5cGk8geXF3aargZL dkI+G3FCa9VO
pjuPsQisoi3xRXQOSL8bFppS58gk0RFVLVVRPfKn358f1TM3+sEfZjz4/vBO TrAeztQAi65n
0FUoJxw8ONUPWnU4S/ntjzVgXWA3jOqAVfLZKapeXVZud8xHCe8Zu7ukSCs3 LzlfWTI9x3nJ
jhK8Li+WZWD7JkrklVZt3W+mzL1HrMVX2P6O4h/PUVrS3nJalV94JXhiGlVR pVOfOhQ09Ue5
M3JFXpLvRumPD4RnUuvUHI1R1dAtLZKfkevMdNJHp36LX2IH7HR0NXObdfIW y9hNlhEbLEPW
WfqusTywytI9xXpfsvX+JEvP5PKey4wdpx9Viql0QvmNOKG1aicUsaIKKL9g 8Ug66WOnfk8t
pqMr45rZhpUzlRNE6cKYBwof7V4w476CqPvzHu15elrPD4Z2rAWLBy26RsoO 3ukwnuLYpEJ2
EOC4p+jwdROkHNhdW/mb0wHRJyhiOYIWY0vVD1qkYBA66KC8is1NTTFVuv7i P86y/deBo6W0
C6PE8dPl/JYnb2XHb3N2//40Q6TI1mZWPuds9U9PlZSaD31ppBxWWIFXmYOP kOHsfCrfZJPT
ZRXXqOk2MYUy2RwgzvShr0poUQaLU7X77dw9r/3D4cdKpN4STMrC5GFoqjnm WetjLzCq6HcW
HbYTWE9bx262Rmy0DNlg6bvO2muN9f7V1i4rrV1TrN1SKrotM7afWgcspRPy 2YgTWqt2ElPK
D9QK5g81rY4pWvdYEZ0Grn3MmDqLXSZdMVmeU8NjfQ2zexmi7zdEdTFEdc2f 2e3M1G4fPNye
gRWZLY3IknjQorPCsJ/VBctxm7rpYK1+Pd0/+nhAfBndA2c275I8ATQZtN+h xbPZF4JmnFWu
aiStWsVZIVfkgRJ2+7XgCd8ry7SZVchbDIk4esXCCtN8t5lTFDr04+CpZ6ik 0tJzGSgEOi8m
p9kB1qD3eUm5/5SWWydXcr6cCIxmVyZ506qGmr5I1QetNE9/xjLneevc/7TF Pm+j87uoHdYp
z1jHbbWO3GIdssna7ylrr/W2bmttnddYO6+2dk4xd15qbDflczadNX1WOmFg aTuhtWonDCy2
rebPGWRInm56Yo5p7dyiJ2LpJNG4KkqmiidMsb1Ms7oZZ3Y2RnUumNH5zKTO fxrcjvUkIl+K
yGVgdT/DIhYDqyvdRMxmEYuOMGrBojmgTbPxc8Nra399wp+OsZZa2WMV9JTF AkvtxDhQc0o/
5picZsGgJr9++qbFQvv+QavM1gP2sgoW4WgvSWkn65x4h+0/xtbS3pBCFzVN v5TmeIWM/5aX
Ufa/wbSM785DbEdP0ZGP4iZGDyo1ZOThoUQzXaOaud1KNMx+3hpDTDxrm7Ld On67NXKb9eGt
1n5bbL022rptsHVaa+uQauuQYm6/xPTvk79wgMXcqpzQYiNOaK3aSWyZFMN0 yHv0IbpGZVw5
k5AyrZltTI2RqTIlRPL0DUtZ0ZxuRdGdTFEdCqd1+HFc+4/C/531ZGyRNCaP sdU/m4F1zy8c
YNEyA6uE7c6WcHFvShVNUtX6V4/7z0kjsLgRXvJk8Id4lItNSauqyDGD51PE ollsxG3g/NJD
fzexkpXXKS3jzqFP+h1Dgf5OnqsIHfxheq7zyIkdYEXlqjeMBRa5deUGs/WA 0wmbiZKqZ3/6
eeiwT3hdF4yc9FxWEbnePOVpy8wd7PSi/l+/rbZem+33bbR1XG9rv8YWlmy+ c3HRbRM+Z9NZ
szGrnMx81jp9h3Xyduu47daR262PbLfJTqiW2gmBFVtG+bnTexbERRpWTDGu mmlcHV1LVdI4
U8LIomW1Z4XF0R2LZrQvnByWOfrOD/vd5gSL2KK4VQsWxS4GVgnFQ/bolhMs 7pYdSDU4Wkfm
9fWv/dN/7vf0gBiZ3+PMZHqk+Mr0PDZztCtk23R85RUr21XRTOz9gh2m0B/P r52/+ErV4j+y
mQeKKB+lscQ/TxSE9nubyiiry+m8CzeoPF9LCPKSKitz7C5ZiJqcvv846wY/ t2hDIcdRuH7/
6aKJMr+4zLnD5ZdUQkZ/3WY+PftWSflkcnONL8rFqLkuiyvomgLdeJ76tHM7 VAne7xlbzy32
Lhvt/7HeftdqW9tE8+3zTUFjHRGrps8qJ9O22aZss07cbh27wxqx3fowgVXj hGqpnVDYi2XX
X3Imdsmf90jhsnGGFVPlPhiTJppWjDU9HlG07OGSuH5yfvG0u4wT2v4YcfuH DwWxnky+zBDi
bLHHZihicbCm07MuDCzaytuP2dMu4uV2I15mvyOV9lK7kXUsbOgm/3kZ/ik3 6PlDMinBGQN4
80TMyfNWpv6kb4i5/f+ssleyucwy1oLF83l5jqZq8eS/2FE2/R3PsjFXUaeV +CrTckWaVBZI
BrzNHSotPZ/1kIWouQXJb7Fthh1gDf2zXEYGi+fkFztObBVnhVkmBpb8R1sL tUslqdGSS5Wh
kUd4xYYXIz6T4quURn46zK/on2QesdY8bmPDYPXZau+xxX7vRvs96+13rLKH LjcHzjX5j/7c
ARbz1hQnyj6rnSyqlOaz6y//GtMhL6Y/XVkgtixfHqIcY8J4Y8JY4+ORpmXD iuIHFS/qUzK/
B+Xb/raveModhjGhPz4S+KcH/J1gEVsE1rASdmOnZleYL02nsy32sCmB5R9/ ISDeFLC8iCzo
cXoQviQouZTZCkNQspHZCkNgopFbQOqNgFT2tCsZEUbGN2VuoQP/GBJ1iueT BS80UQ7jY+p3
vICc38gieXCGh5gs2ZWyvJwm/852Rx8NXF4hF1YmuLfABBtl0q8D1toeyv2X q4ROPMYGMvwQ
9/zMRzcOfHGRpwlftv1UVlG7VD509FGy2oqKRdrkQiOPklFCaVT97rkVPZex ezXD15ojN1gi
N1gjnrQMf8oydKNl0CZr3022nhttXZ+ydVxnuyvVfnuSLTDe7D/b6BfpOCt0 eHPXCdG5iG0/
50feTXvDvDnhBQuHF8ZFFi6JLIyLMMQNN8QNNS4eZFrYt+ixnsVzutJ+kMJV 0YTbCyMDzwz2
/6CXH+vJjApn0CKw6A4hA+snaSx8OcAiquhQyfHs89WAldeC6Gn3NdfpMXb+ JDt/zl02nl/7
YHtqNRHGrcEZbR2ZeRdvUCR+5ZCZhvPnDBa96PidthbXRkfV74i+2Hnh5d7L rwxIujJ4ZdmQ
VWXhq8rDV5f3X1Pe54nynk9UdF1T0XG1OSzFTDvB4PgK/wVXpKh8aQR7uoE3 6qYTOexlDr3j
3PjO52f0/tesATmxg3MfG5IbG547Nzxvbv/82D6Fs3sWRnc1zOhomBJmGN+2 cFRw7jD/kwOk
A90lJ1icLQLLuSusCxZni4GVdJXe6eFvXzCq6oHFX53QYkuGrHkTrs13I7WS 99/IOG/m+3Ta
D57MrWTxTBGobqlFw6XrveNywh7N6RSb021Bfs9Feb0W5/ZYlNc9Lr9bXH6X uPxOSwzt4wxh
i413LDSEzjO2mWP0m5kvTTzVdebfZLDcdMLCXnyV4eL176b2PjEs7MSoTmkT uqVN7pk2uVfa
pB7pk7ufnNQtY2KX0xM7nR7X/syYsNORd5wZHnr64TYnB/r9vY/07siuDKwY szNocbDY5QYF
WPyVDB60eNwKSqlU47XOGcO0qLolZX2xMO1Aae/J9+m0i1TtSW9pRCvesKaf Les996u2o/96
14TP2k389O6Jh9tNOBw28UjYpM/unHi07cQvbpv4ZciEr+hoPWD0F36jv5Ii jnadeTgt8yLV
5W254yTxNxYOVuLrlktn0g9N6P32Q23fG3jXu+Ht3hl09zsD2703KOzgoLD3 w+/8cGDbj/rf
9pd+IR/2Cfqwd8BfHvB7v4f03siuJT+kJf6SLlg0DBYdvDuOsRwXOemXrnky Y6GL3r1x4MVt
VRU32lHWNz5OHu1aiKmOaVraYmDiNZpa5ZF1U9IUXagW1eXDcd3J6xWBS23s 1HJRZWCcLfHX
7JLYLf0ZLlQRVYGPltc5xlJELAdYdM+Inm5wPv/veFPM8e5Y7TtMyhe8kthp oMpokPycqP55
fvPl1DkLU52UeXGxxWhC54COo3U6E2SXwehaw2NWaZ6NGSVizSz28F+ekC3m ijTjMl1Kda6l
Iyp+UKWyurvCXMcVh1z2Es/4NL8J6fT8O3sEvuZ1H3oNiBt7xJT4Y4/fO4y9 YlaT5gnHHU2Y
WoFJdKWwZRjNMj3O0GBnxmezp6fI6E4Mt1FnnYs8n4zn0C/dGSSju8z8FiEl 6Jcoahis8WkM
LAdbMl4cMpXxAszk8oqKtWvlYs2UoOG0BHOqxCVqbhMoCL+l4zwr7JgWPORs +5RLIbHnb2n/
isJQQKWANKVMijgrdXtHCtspSQALgHhIAYDlISHhpq4CAAtECFEAYAmRFU4B FhgQogDAEiIr
nAIsMCBEAYAlRFY4BVhgQIgCAEuIrHAKsMCAEAXUYIXiXqEQnXXnlIFFz0Tc +6bzXiHA0h0C
YgYMsMToqnuvAEv3CIgRAGCJ0VX3XgGW7hEQIwDAEqOr7r0CLN0jIEYAgCVG V917BVi6R0CM
AABLjK669wqwdI+AGAHUYIWEZ+G9QjFS68srwNLXfHtttADLa1LrqyGApa/5 9tpoAZbXpNZX
QwBLX/PttdECLK9Jra+GAJa+5ttrowVYXpNaXw0BLH3Nt9dGC7C8JrW+GlKD FRyeiVs6+kJA
zGidYHWpef0LYInRWXdeAZbuptw7AwZY3tFZd60ALN1NuXcGDLC8o7PuWgFY upty7wwYYHlH
Z921ArB0N+XeGTDA8o7OumsFYOluyr0zYIDlHZ111wrA0t2Ue2fAAMs7Ouuu FYCluyn3zoAB
lnd01l0rAEt3U+6dAQMs7+isu1YAlu6m3DsDBlje0Vl3rQAs3U25dwYMsLyj s+5aAVi6m3Lv
DBhgeUdn3bWiBisE7xXqjgEhA2ZgjaL/Vm6f87+VA1hCZNafU4Clvzn3yogB lldk1l8jAEt/
c+6VEQMsr8isv0YAlv7m3CsjBlhekVl/jQAs/c25V0YMsLwis/4aAVj6m3Ov jBhgeUVm/TWi
BgufitQfA0JG7LgJfV7qUnOvUAbrQnEmDAq4rADAwvYjRAGAJURWlzf0VlMR YAEsIQoALCGy
tprA4/JAABbAEqIAwBIiq8sbequpCLAAlhAFAJYQWVtN4HF5IAALYAlRAGAJ kdXlDb3VVFSD
Jb/+1WpGiIE0iwLOF1bvrfn/CgFWs0xD62sUYGFXKEQBgCVE1tYXgW51RAAL YAlRAGAJkfVW
t+/WVx5gASwhCgAsIbK2vgh0qyMCWABLiAIAS4ist7p9t77yAAtgCVGgPlhZ 7VMuhcSeb33b
EEbkTQWcYHWpvaUDsIRswd6c1JbQFsACRkIUAFhCZG0JMaN5+wCwAJYQBQCW EFmbN1q0hNYB
FsASogDAEiJrS4gZzdsHgAWwhCgAsITI2rzRoiW0DrAAlhAFAJYQWVtCzGje PqjBCh6EWzpA
zQMK1LxXWHOvEGA174bealoHWB7YOlsNDR4cCMACWEIUAFhCZPXgpu+jrgAW wBKiAMASIquP
hhkPdhtgASwhCgAsIbJ6cNP3UVcAC2AJUQBgCZHVR8OMB7sNsACWEAXUYOGL fh7cavXsqv7T
DZl4YVXPQHhq7ABLyI7AU9Pju34AFsASogDAEiKr70YaT/UcYAEsIQoALCGy emq7910/AAtg
CVEAYAmR1Xcjjad6DrAAlhAFAJYQWT213fuuH4AFsIQogPcKhcjqu5HGUz0H WABLiAIAS4is
ntrufdcPwAJYQhQAWEJk9d1I46meAyyAJUQBgCVEVk9t977rB2ABLCEKACwh svpupPFUzwEW
wBKiAMASIquntnvf9QOwAJYQBXATWoisvhtpPNVzBtaobKnLPilspyR1TMML q55SVud+ABYi
lhAFAJYQWXUermj4AAtgCVEAYAmRFRELYAEsIQoALCGyImIBLIAlRAGAJURW RCyABbCEKFAf
LPy3ckKE1lsMA1jASIgCAEuIrHqLT/XHC7AAlhAFAJYQWRGxABbAEqIAwBIi KyIWwAJYQhQA
WEJkRcQCWABLiAIAS4isiFgAC2AJUQBgCZEVEQtgASwhCgAsIbIiYgEsgCVE AYAlRFZELIAF
sIQoALCEyIqIBbAAlhAFAJYQWRGxABbAEqIAwBIiKyIWwAJYQhQAWEJkRcQC WABLiAIAS4is
iFgAC2AJUQBgCZEVEQtgASwhCgAsIbIiYgEsgCVEAYAlRFZELIAFsIQoALCE yIqIBbAAlhAF
AJYQWRGxABbAEqIAwBIiKyIWwAJYQhQAWEJkRcQCWABLiAIAS4isiFgAC2AJ UQBgCZEVEQtg
ASwhCgAsIbIiYmmCNf/FMzAo4LICmmDN2PIdDAq4rIAmWKNXf60T6z1oMhkf rOi0TiSlYWqC
NTj+U50YwbR0w39XV1fTeEWndSIpDVMTrF6zP9KPEVX0x8crOq0TVTXB6jjp jzAo4LICmmD9
24jfw6CAywpogvVtXhUMCrisgCZYx3OuwaCAywpognXs/FUYFHBZAU2wvjpX CYMCLiugCdaX
WXYYFHBZAU2wPv/RDoMCLiugCdaR0zYYFHBZAQdY56V790lhOyWpY1pIeFb7 lEshsec/OWWF
QQGXFdAE6+MMCwwKuKyAJliH0s0wKOCyAppgffR9hVC7L+olMqFNwHkzKqAJ 1gcnylXGUZCt
foFbyuF+bqlKI4U9681TvdKzH02wDn5TpjQ+c6pMdxY97tCdzqCuxxXQBOvA 8StK4xw0kikX
UAU2uYoynzIbLKZ0wiuqajWlYuNVVEPAoiAFNMH647HLSlNxwFfxTFX6ppk3 rSt7uKmrBks2
pT+q0WHR4wpogvW/X19WmYotvlaZqcxRpXkxpUNljpxWFbtpmaZXrN/P+gNE jgcV0ATrrb9f
0jI+SXytcsKUOaq0skrTi9VvSG6xEf+qtuo33cjQsMpTCmiC9eYXF7WMT5W8 tpFFeZWqDNVV
5mgVu2mZ+hUbb6iRQWGVZxVgYEVmS13q3dJ54+gFpan2g/VXyTm8JF+sn5Zz GiymzFR6aNyn
sqEG+9lI51XDxKKnFNAE6zdHSptifM6aUhJldKWAJlivf1LSFONgNaUkyuhK AU2wfn24GAYF
XFZAE6xXPy6CQQGXFdAEa88hEwwKuKyAJliv/NkIgwIuK6AJ1s4PDTAo4LIC mmC9/IEBBgVc
VkATrBcPFsKggMsKaIL1wrsFMCjgsgJqsIJr3tJ57p18GBRwWQFNsHbsz4NB AZcV0AQrYNir
MCjgsgKaYLn8YSRUhAKkgCZY/8ypgkEBlxXQBOvY+WswKOCyAppgfZ19FQYF XFZAE6wvz1bC
oIDLCmiC9XmmHQYFXFZAE6wjZ2wwKOCyAppgffKDFQYFXFZAEyyXP4yEilCA FNAEy+UPI6Ei
FCAFHGDRpyLfdH4qUr4J3YyfVmo1Td8e1mnq1GgaDiXmzo1zeVy+6EcTrD+d qIC5rwAxERu7
+N13P6XEwIFDXHboc340wTr4TTnMfQV2735DkqSIiLEsEXLngAFDXPPpc340 wTpwvAzmvgIE
U8SIsfvf/rj7g4MH9B/sskOf86MJ1h+PXYG5qQDR0H/IaHJy/4ODR4wY47I3 X/SjCZYHP5UE
VzpUQBMsT30nCX70qYAmWJ79WhK86U0BTbA89Z0k+NGnAppg6epjTuIGOyN6 ydgxUx/qM5Db
z3e96VpbPudHE6zXPy2BeUSBrr160KUs+tux4xfuOPQtP5pgufxhJFSsr0Cf AREvv/Q795Xx
IT9OsLrUu1f46sfFMCjgsgKaYO05VASDAi4roAnWK382waCAywpogrXzQyMM CrisgCZYLn8Y
CRWhACmgCZbLH0ZCRShACmiC5fKHkVARCpACmmC5/GEkVIQCpIAmWC5/GAkV oQApoAmWyx9G
QkUoQAoALHxfTogCAEuIrAhaDKxR9P8V1rtXCGmggDsKACxELCEKACwhsrqz rbeOugALYAlR
AGAJkbV1RB13RgGwAJYQBQCWEFnd2dZbR12ABbCEKACwhMjaOqKOO6MAWABL iAIAS4is7mzr
raOuA6zzUpd96k9Fto7hYRTNpQDAQsQSogDAEiJrc8WJltMuwAJYQhQAWEJk bTmRo7l6ArAA
lhAFAJYQWZsrTrScdgEWwBKiAMASImvLiRzN1ROABbCEKACwhMjaXHGi5bSr BiskPKt9yqWQ
2PMtp4voiS8q4ARL/m/lAJYvzmIL7DPAwq5QiAIAS4isLTCEeLlLAAtgCVEA YAmR1cvhoQU2
B7AAlhAFAJYQWVtgCPFylwAWwBKiAMASIquXw0MLbA5gASwhCgAsIbK2wBDi 5S6pwQoOz8S9
Qi/PQatsjoEVSZ+KrH2vEGAhhnlAAYDlARFbZchxc1AAC2AJUQBgCZHVzc29 FVQHWABLiAIA
S4isrSDkuDkEgAWwhCgAsITI6ubm3gqqAyyAJUQBgCVE1lYQctwcAsACWEIU UIOF17/c3FJR
nStQA1bNfysHsECGRxQAWEJ2BB6ZG592ArAAlhAFAJYQWX062Hik8wALYAlR AGAJkdUjG71P
OwFYAEuIAgBLiKw+HWw80nmABbCEKACwhMjqkY3ep50ALIAlRAE1WMGD8A1S IUL7dPhxofOO
F1azpXvl9woBluMeKsxNBQAWGBKiAMASIqubm3srqA6wAJYQBQCWEFlbQchx cwgAC2AJUQBg
CZHVzc29FVQHWABLiAIAS4isrSDkuDkEgAWwhCigBgtv6bi5paI6Xv8SsqUC LIAFsAQqgMdm
BIqr5+gFsACWEAUAlhBZ9RyrcIwFpAQqgIglUFw9xy2ABbCEKACwhMiq51iF YywgJVABRCyB
4uo5bgEsgCVEASdY9+JTkXjly6MKACwh26ued4J1Dt4RsYCCZxVAxELEEqIA wBIiq2e3fl/0
BrAAlhAFAJYQWX0xxni2zwALYAlRAGAJkdWzW78vegNYAEuIAgBLiKy+GGM8 2+cGwGo3y9A+
5VJI7PngR0uUxorCoEATFYjMlvodlZRX3ttOPnvnnJzbpma1GZupNGnU+TpG NZto9C1KpUWe
l+pY437qFla5Unap8c403vmbDE3VYeXirXRe1UPXZfGcgDeZi0ZG2ogmtCpb Gpou9T0idXlL
CtspSe3fl7q86bB9NQm+2KBRGaVplyRsGzGVc1XJOk3sU/tppAP0WVWlqYeg 6nzdRVXdRlyp
VzXqVlNJWfOm6anS5CZuG5lBmhc3VFJ3Q9X5txgenX7jAOvu19k/MCjgUQX+ H6p304FhcIgQ
AAAAAElFTkSuQmCC
--------------020908000302070109020904--
Re: Strange resizing behaviour of CollapsibleButtons [message #60152 is a reply to message #58558] Fri, 17 October 2008 09:08 Go to previous message
Is there any progress on this issue?
>> Hi Emil.
>> not work properly.
>> Thanks,
>> Mario
>>> Hello Mario.
>>> widget are related to the fact that it's a quite difficult widget to
>>> get "into a corner" where it behaves normally.
>>> Regards,
>>> Emil
>>>> control below.
>>>> similar to the sash in the sash form? I'm thinking of the way it is
>>>> done in MS Outlook.
>>>> applicable in a production environment. (I've downloaded the 1.0
>>>> nightly build binaries - maybe there is a stable version somewhere?)
>>>> Thanks,
>>>> Mario
Re: Strange resizing behaviour of CollapsibleButtons [message #591951 is a reply to message #58364] Wed, 27 August 2008 15:16 Go to previous message
Hello Mario.
Emil
> Outlook.
> Mario
Re: Strange resizing behaviour of CollapsibleButtons [message #591988 is a reply to message #58389] Fri, 29 August 2008 09:10 Go to previous message
Hi Emil.
work properly.
Mario
> Hello Mario.
> Emil
>> Outlook.
>> Thanks,
>> Mario
Re: Strange resizing behaviour of CollapsibleButtons [message #592006 is a reply to message #58534] Fri, 29 August 2008 12:04 Go to previous message
> Hi Emil.
> work properly.
> Mario
>> Hello Mario.
>> Regards,
>> Emil
>>> control below.
>>> MS Outlook.
>>> Thanks,
>>> Mario
AAAAAElFTkSuQmCC
Re: Strange resizing behaviour of CollapsibleButtons [message #592586 is a reply to message #58558] Fri, 17 October 2008 09:08 Go to previous message
>> Hi Emil.
>> not work properly.
>> Thanks,
>> Mario
>>> Hello Mario.
>>> Regards,
>>> Emil
>>>> control below.
>>>> done in MS Outlook.
>>>> Thanks,
>>>> Mario
Previous Topic:[Gantt] Workaround for scrollbars
Next Topic:CompositeTable selection question
Current Time: Sun Jul 13 14:28:37 EDT 2025
Powered by FUDForum. Page generated in 0.04039 seconds
