Home » Archived » M2M (model-to-model transformation) » [ATL] Running an ANT file with java
[ATL] Running an ANT file with java [message #58327] Fri, 17 August 2007 12:01 Go to next message
Hello everybody,
I don't know if this newsgroup is the correct place to post my problem, but
I will try.
I have an ANT script (build.xml) that executes several ATL transformations.
I want to run that build.xml file from java, but I don't know how. I have
tried with:
Process proce = Runtime.getRuntime().exec("cmd /c
"+ant_home+"/bin/ant -buildfile
c:/eclipse3.3/runtime-New_configuration/Plugin/src/plugin/po pup/actions/build.xml ");
InputStream is = proce.getInputStream();
BufferedReader br = new BufferedReader (new InputStreamReader (is));
String aux = br.readLine();
while (aux!=null)
}catch(Exception e){
System.out.println("Error: "+e.getMessage());
The problem is that only the first sentence in the ANT file is executed, but
not all the script. Why?
Any idea?
Thank you very much in advance
Bea
Re: [ATL] Running an ANT file with java [message #58379 is a reply to message #58327] Fri, 17 August 2007 16:40 Go to previous messageGo to next message
Examples of running ant scripts from Java code (more specifically from
an Eclipse plugin) are available in AM3. See the ActionAnt... classes in:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmt/AM3 /org.eclipse.am3.ui/src/org/eclipse/am3/ui/action/?root=Tech nology_Project
Note that this implementation has one flaw though: the ant console is
not displayed.
As far as I know, the AM3 ant tasks have not been adapted to work
outside of Eclipse yet.
Frédéric Jouault
bea wrote:
> Hello everybody,
> I will try.
> tried with:
> while (aux!=null)
> Any idea?
> Bea
Re: [ATL] Running an ANT file with java [message #58801 is a reply to message #58379] Mon, 20 August 2007 15:42 Go to previous message
I have been looking the webpage but I don't know what variable correspond to
the ant script.
Could anybody tell me where I can find the ATL API? or help me with the java
code?
Thank you in advance
Bea
"Fr
Previous Topic:[ATL]Java Heap Space Error importing ECore Model
Next Topic:[ATL] New use case - Variability management in MDSPL
Current Time: Mon Jul 21 21:07:47 EDT 2025
Powered by FUDForum. Page generated in 0.03756 seconds
