Home » Archived » Test and Performance Tools Platform (TPTP) » InactiveProcessException when starting TPTP JUnit Plugin
InactiveProcessException when starting TPTP JUnit Plugin [message #58298] Wed, 15 March 2006 02:20 Go to next message
I have followed the guide for creating a TPTP JUnit Plugin test that is
located
at:
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. hyades.test.doc.user/concepts/cintro.htm
Finnaly I click on the testsuite file and select Run As -> Run..., and then
select the test suite and the deployment. When I click on the Run button a
progress monitor is shown wiht the task "Preparing and deploying". But the
task never ends - the following exception is thrown:
org.eclipse.hyades.internal.execution.local.control.Inactive ProcessException
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:417)
org.eclipse.hyades.execution.harness.TestExecutionHarness.la unchTestExecution(TestExecutionHarness.java:2058)
org.eclipse.hyades.execution.harness.TestExecutionHarness.ac cess$2(TestExecutionHarness.java:1856)
org.eclipse.hyades.execution.harness.TestExecutionHarness$2. run(TestExecutionHarness.java:692)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
The session data of the exception is:
eclipse.buildId=I20051215-1506
java.version=1.5.0_05
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=bg_BG
Command-line arguments: -data /home/kiril/work/workspace -os linux -ws gtk
-arch x86
I use eclipse3.2M5 and I have downloaded
http://www.eclipse.org/tptp/home/downloads/drops/TPTP-4.2.0- 200603140100.html
I use a remote Agent Controler.
Re: InactiveProcessException when starting TPTP JUnit Plugin [message #58689 is a reply to message #58298] Wed, 15 March 2006 17:04 Go to previous messageGo to next message
Eclipse built on 12/15/2005 was 3.2M*4*. Again, to run with TPTP 4.2M5
(02/28 and beyond) you need 3.2M5a (built 02/23/2006).
RDS
> located
> at:
> the task never ends - the following exception is thrown:
> at
> at
> at
> at
> -arch x86
Re: InactiveProcessException when starting TPTP JUnit Plugin [message #59373 is a reply to message #58689] Mon, 20 March 2006 12:11 Go to previous messageGo to next message
I have downloaded the eclipse 3.2 M5a
and I could not make it work.
The same problem still occures.
Re: InactiveProcessException when starting TPTP JUnit Plugin [message #59458 is a reply to message #59373] Mon, 20 March 2006 18:45 Go to previous messageGo to next message
If someone on the TPTP team that isn't tied up at EclipseCon this week
has an opportunity to look into this, Kiril has MUCH more extensive info
on the problem up at the end of the long chain entitled "TPTP crashes
eclipse help".
RDS
kiril mitov wrote:
> I have downloaded the eclipse 3.2 M5a and I could not make it work.
Re: InactiveProcessException when starting TPTP JUnit Plugin [message #64435 is a reply to message #59458] Wed, 05 April 2006 11:51 Go to previous messageGo to next message
Originally posted by: alberto.devega.thalesgroup.com
I have the same problem here. I record an HTTP test, generate the code and
so on, and when I try to Run the Test, I get this error:
!ENTRY org.eclipse.hyades.test.core 1 0 2006-04-05 17:28:36.687
!MESSAGE
!STACK 0
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.hyades.test.core 1 0 2006-04-05 17:30:04.843
!MESSAGE
!STACK 0
My configuration:
eclipse.buildId=M20060118-1600
java.version=1.4.2_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=es_ES
Command-line arguments: -os win32 -ws win32 -arch x86
Eclipse 3.1.2
TPTP 4.1.0.1
Thanks in advance
Re: InactiveProcessException when starting TPTP JUnit Plugin [message #66358 is a reply to message #64435] Thu, 13 April 2006 12:50 Go to previous message
Originally posted by: bharat51.hotmail.com
Hi Guys,
Did you manage to resolve this InactiveProcessExceptionIssue??
Cheers
Bharat
Previous Topic:AGR: Headless test run
Next Topic:GUI recorder - wait until job completed
Current Time: Fri Jul 18 11:48:37 EDT 2025
Powered by FUDForum. Page generated in 0.18061 seconds
