jars.extra.classpath and running plugins within Eclipse [message #58297] |
Fri, 24 April 2009 07:54  |
I have a plugin that relies on several JARs to work. Currently I include
them in the plugin with "jars.extra.classpath" in build.properties. That
at least leads to the JARs being included in the exported plugin.
However, when I try to test my plugin by running an "Eclipse
Application" with the plugin (workspace version) enabled, I get
ClassNotFoundExceptions when the plugin tries to access one of those JARs.
Now here's my question: How can I make those JARs available to an
Eclipse instance running as "Eclipse Application"?
Thanks for any help,
Jochen
Re: jars.extra.classpath and running plugins within Eclipse [message #59030 is a reply to message #58388] |
Thu, 30 April 2009 14:34  |
Hi Andrew,
putting the JARs on the Bundle-ClassPath did not change anything.
And the rest on the page you linked looks like I have to change the
entire class-loading code? That looks like a lot of overkill to use a
simple JAR file.
Jochen
Andrew Niefer wrote:
> The jars.extra.classpath is a compile-time thing and doesn't affect
> runtime.
> This is useful because there are some cases (ie contributing ant tasks,
> because of class loader issues) where you don't want the jars to be
> available to the bundle at runtime.
> If you want them available at runtime, you need to put them on your
> Bundle-ClassPath or do something with buddy class loading.
> http://wiki.eclipse.org/index.php/Context_Class_Loader_Enhan cements
> -Andrew
> Jochen wrote:
>> include them in the plugin with "jars.extra.classpath" in
>> build.properties. That at least leads to the JARs being included in
>> JARs.
>> Jochen
Re: jars.extra.classpath and running plugins within Eclipse [message #596389 is a reply to message #58297] |
Fri, 24 April 2009 16:23  |
The jars.extra.classpath is a compile-time thing and doesn't affect runtime.
-Andrew
Jochen wrote:
> Jochen
Re: jars.extra.classpath and running plugins within Eclipse [message #596577 is a reply to message #58388] |
Hi Andrew,
simple JAR file.
Jochen
> runtime.
> -Andrew
> Jochen wrote:
>> JARs.
>> Jochen
FUDForum. Page generated in 0.08562 seconds
