Home » Language IDEs » AspectJ » How to use the MethodSignature.getReturnType()
How to use the MethodSignature.getReturnType() [message #58267] Thu, 10 November 2005 17:46 Go to next message
Originally posted by: aim.yahoo.com
Hi --
I am novice to Eclipse AJDT. I am trying to get the retrun type of a
signature in an advice.
I am using the following code to get that :
AdviceSignature adviceSig =
((AdviceSignature)thisJoinPoint.getSignature());
But when I execute my AspectJ project it's throwing a classcastexception
as follows:
java.lang.ClassCastException
com.sequence.Sequence.ajc$before$com_sequence_Sequence$1$b31 4f86e(Sequence.aj:34)
at com.sequence.Figure.main(Figure.java)
Exception in thread "main"
I also tried to use MethodSignature class to get the return type of the
signature but same result (Exception)
Thanks in Advance
Aim
Re: How to use the MethodSignature.getReturnType() [message #58293 is a reply to message #58267] Thu, 10 November 2005 21:12 Go to previous messageGo to next message
Hi Aim,
The sub-interface of Signature in which you can cast the result of
thisJointPoint.getSignature() depends on what join-point your pointcut
matched.
Say you defined a pointcut foo()
pointcut foo() : call(* MyClass.myMethod(..));
Then your pointcut will match all MyClass.myMethod() method call
join-points.
Thus you can cast the Signature instance in a MethodSignature instance.
And so you may define an advice
before() : foo()
MethodSignature signature = (MethodSignature)
thisJoinPoint.getSignature();
Class returnType = signature.getReturnType();
System.out.println(returnType.getName());
If you are not sure of what join-points matches your pointcut, you can
test if the Signature object instanceof MethodSignature.
Now, AdviceSignature is the type of the signature object when your
pointcut matches an advice call join-point.
Hope i was understandable!
Didier.
Rakesh wrote:
> Hi --
> as follows:
> at
> Thanks in Advance
> Aim
Re: How to use the MethodSignature.getReturnType() [message #58315 is a reply to message #58293] Fri, 11 November 2005 10:39 Go to previous message
Thanks a lot Didier. The solution you gave me solved my problem. I need
to read about these different types Join-point we can have in a pointcut.
Aim
Re: How to use the MethodSignature.getReturnType() [message #590824 is a reply to message #58267] Thu, 10 November 2005 21:12 Go to previous message
Hi Aim,
matched.
join-points.
before() : foo()
Didier.
Rakesh wrote:
> Hi --
> as follows:
> at
> Thanks in Advance
> Aim
Re: How to use the MethodSignature.getReturnType() [message #590839 is a reply to message #58293] Fri, 11 November 2005 10:39 Go to previous message
Aim
Previous Topic:How to use the MethodSignature.getReturnType()
Next Topic:Refactoring support
Current Time: Sun Aug 31 21:11:38 EDT 2025
Powered by FUDForum. Page generated in 0.06936 seconds
