Home » Archived » BIRT » problem generating reports with charts & images
problem generating reports with charts & images [message #58264] Thu, 14 July 2005 07:54 Go to next message
Originally posted by: er.vikas.rediffmail.com
I am facing a problem while generating reports that contains Chart &
images using the BIRT report engine.I am creating the report
templates with the eclipse BIRT plugin.These templates i am giving as
an input to BIRT engine which is a part of my web application.
This successfully
generate(HTML format) the report but when i open the report,the
images & charts are not displayed.
In the BIRT site they r saying that we have to set the image handler
i,e CompleteHTMLImageHandler or ServerHTMLImageHandler.
I have used both the options but of no use.
Can anyone help me in setting the configuration for the BIRT to
support images & charts.
Thanks in advance
Re: problem generating reports with charts & images [message #58428 is a reply to message #58264] Thu, 14 July 2005 14:29 Go to previous message
Vikas,
You have to set the image directory and base image URL right like this
below:
HTMLRenderContext renderContext = new HTMLRenderContext( );
renderContext.setImageDirectory( EngineAccessor.ImageDirectory );
renderContext.setBaseImageURL( request.getContextPath( ) +
EngineAccessor.ImageBaseUrl );
The image base url will be used to construct the URL of your embedded
image/chart in the report. The image directory is the physical location
engine uses to store generated image/chart. You have to make sure the
image can be loaded by the url constructed from that base image url.
For example in Birt viewer, we define image dir as "/report/images", base
image url to be "/report/images" too. Also make sure the "/report/images"
is available in your web app's doc root. This is a very simple and quick
solution and you can develop more advanced one.
Jun Zhai
Previous Topic:Migrating our reports to BIRT
Next Topic:BiRT Report Engine Queuing
Current Time: Sun Aug 31 21:13:41 EDT 2025
Powered by FUDForum. Page generated in 0.03041 seconds
