Home » Archived » M2M (model-to-model transformation) » [ATL] : Exception when using two variable in the "from" action
[ATL] : Exception when using two variable in the "from" action [message #58227] Fri, 17 August 2007 10:24 Go to next message
Originally posted by: youssef.srour.etu.univ-nantes.fr
When I use two variables in the "from" action I obtains an exception.
My metamodel is "UML1.3"
rule statemachine{
from
stateMachineIn : UML!StateMachine,
contextClass : UML!Classifier--(stateMachine."context"=contextClass)
-- When I add "contextClass" as variable I would have the
exception
to
stateMachine : UML!StateMachine(
namespace<-stateMachineIn.namespace
do{
The exception code :
****** BEGIN Stack Trace
exception:
java.util.EmptyStackException
at java.util.Stack.peek(Unknown Source)
at java.util.Stack.pop(Unknown Source)
at org.atl.engine.vm.ASMStackFrame.pop(ASMStackFrame.java:90)
at org.atl.engine.vm.ASMStackFrame.popVariable(ASMStackFrame.ja va:118)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:23 2)
at org.atl.engine.vm.ASMOperation.exec(ASMOperation.java:155)
at org.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java: 60)
at org.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java: 50)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:21 4)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:30 9)
at org.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:276)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:1 36)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:9 4)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:6 8)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:6 4)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:230)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:168)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:145)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:121)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .launch(AtlLaunchConfigurationDelegate.java:97)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:639)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:754)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:944)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
A.main() : ??#24 null
local variables = {self=StatePatern : ASMModule}
local stack = []
A.__exec__() : ??#8 null
local variables = {e=TransientLink {rule = 'statemachine', sourceElements
= {stateMachineIn = IN!<notnamedyet>}, targetElements = {stateMachine =
OUT!<notnamedyet>}, variables = {}}, self=StatePatern : ASMModule}
local stack = []
A.__applystatemachine(1 : NTransientLink;) : ??#7 null
local variables = {stateMachineIn=IN!<notnamedyet>, link=TransientLink
{rule = 'statemachine', sourceElements = {stateMachineIn =
IN!<notnamedyet>}, targetElements = {stateMachine = OUT!<notnamedyet>},
local stack = []
****** END Stack Trace
Execution terminated due to error (see launch configuration to allow
continuation after errors).
Re: [ATL] : Exception when using two variable in the "from" action [message #58303 is a reply to message #58227] Fri, 17 August 2007 11:08 Go to previous messageGo to next message
Originally posted by: quentin.glineur.obeo.fr
--------------060607010904040904090001
Content-Type: text/plain; charset=ISO-8859-15
This is so because the pattern you use to match contextClass is using a
reference to itself. In your case, I guess you are trying to make
reference between matched objects for a multi class pattern. This can be
done by using the binding alias in the definition of the pattern.
Quentin GLINEUR
Youssef SROUR a
Re: [ATL] : Exception when using two variable in the "from" action [message #58402 is a reply to message #58227] Fri, 17 August 2007 16:46 Go to previous messageGo to next message
Can you please tell us, which version of ATL (2004 or 2006) you are using?
Note that ATL 2004 does not support multiple source pattern elements.
This may be the cause of the error you get.
Frédéric Jouault
Youssef SROUR wrote:
> rule statemachine{
> from
> exception
> to
> do{
> exception: java.util.EmptyStackException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> local stack = []
> sourceElements = {stateMachineIn = IN!<notnamedyet>}, targetElements =
> {stateMachine = OUT!<notnamedyet>}, variables = {}}, self=StatePatern :
> ASMModule}
> local stack = []
> link=TransientLink {rule = 'statemachine', sourceElements =
> local stack = []
Re: [ATL] : Exception when using two variable in the "from" action [message #58694 is a reply to message #58402] Mon, 20 August 2007 04:37 Go to previous messageGo to next message
Hello
I use the version of "Septembre 16, 2005"
thank you
Re: [ATL] : Exception when using two variable in the "from" action [message #59151 is a reply to message #58694] Thu, 23 August 2007 14:33 Go to previous message
I am a bit confused.
Do you mean you try to use ATL 2006 with a build dating from September 2005?
Even if you put
-- @atlcompiler atl2006
at the beginning of your transformation, ATL 2006 will not be used,
because it did not exist at that time.
You should probably install a new version (e.g., 2.0RC2, available from:
http://www.eclipse.org/m2m/atl/download/).
Frédéric Jouault
Previous Topic:[ATL]Problem generating Model
Next Topic:ATL Newbie
Current Time: Sun Aug 31 17:56:26 EDT 2025
Powered by FUDForum. Page generated in 0.03565 seconds
