Home » Modeling » TMF (Xtext) » No getter or adder for 'genmodels' (EcoreGeneratorFragment)
No getter or adder for 'genmodels' (EcoreGeneratorFragment) [message #58208] Tue, 14 July 2009 05:27 Go to next message
Hi @all,
I try to run the MWE workflow but get an error message:
343 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - [ERROR]: No
getter or adder method for property 'genmodels' in clazz
'org.eclipse.xtext.generator.ecore.EcoreGeneratorFragment' found.
The grammar file imports UML metamodel:
import "http://www.eclipse.org/uml2/3.0.0/UML" as test
And the workflow file establish the reference to the genmodel:
<fragment class="org.eclipse.xtext.generator.ecore.EcoreGeneratorFragment ">
<genmodels
value=" platform:/resource/org.xtext.example.mydsl/src/org/xtext/exa mple/UML.genmodel "/>
</fragment>
ILyas
Re: No getter or adder for 'genmodels' (EcoreGeneratorFragment) [message #58233 is a reply to message #58208] Tue, 14 July 2009 05:28 Go to previous messageGo to next message
Hi Ilyas,
please try genModels with an uppercase M instead.
Hope that helps,
Sebastian
Am 14.07.2009 11:27 Uhr, schrieb Ilyas Keser:
> Hi @all,
> <genmodels
> </fragment>
> Thanks
> ILyas
Re: No getter or adder for 'genmodels' (EcoreGeneratorFragment) [message #58255 is a reply to message #58233] Tue, 14 July 2009 05:37 Go to previous messageGo to next message
Hi Sebastian,
thanks, I should open the class EcoreGeneratorFragment:
public void setGenModels(String uris)
ILyas
Re: No getter or adder for 'genmodels' (EcoreGeneratorFragment) [message #58305 is a reply to message #58255] Tue, 14 July 2009 07:33 Go to previous messageGo to next message
The path to the UML genmodel is:
/org.xtext.example.mydsl2/src/org/xtext/example/UML.genmodel .
The workflow file establishes the reference to the genmodel with:
<genModels
value=" platform:/resource/org.xtext.example.mydsl2/src/org/xtext/ex ample/UML.genmodel "
</fragment>
Running the workflow file reports following error:
EcoreGeneratorFragment - Couldn't find genmodel for uri
'platform:/resource/org.xtext.example.mydsl2/src/org/xtext/e xample/UML.genmodel'
Any ideas?
ILyas
Re: No getter or adder for 'genmodels' (EcoreGeneratorFragment) [message #58330 is a reply to message #58305] Tue, 14 July 2009 07:44 Go to previous messageGo to next message
After adding platformUri to the StandaloneSetup:
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
<platformUri value="${runtimeProject}/.." />
<registerGeneratedEPackage value="org.eclipse.uml2.uml.UMLPackage"/>
</bean>
... running workflow reports:
org.eclipse.emf.common.util.WrappedException:
org.eclipse.emf.codegen.jet.JETException: InvocationTargetException
org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAda pter.generateJava(AbstractGeneratorAdapter.java:1112)
org.eclipse.emf.codegen.ecore.genmodel.generator.GenClassGen eratorAdapter.generateClass(GenClassGeneratorAdapter.java:14 7)
org.eclipse.emf.codegen.ecore.genmodel.generator.GenClassGen eratorAdapter.generateModel(GenClassGeneratorAdapter.java:10 7)
org.eclipse.emf.codegen.ecore.genmodel.generator.GenBaseGene ratorAdapter.doGenerate(GenBaseGeneratorAdapter.java:220)
org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAda pter.generate(AbstractGeneratorAdapter.java:290)
org.eclipse.emf.codegen.ecore.generator.Generator.generate(G enerator.java:617)
org.eclipse.emf.codegen.ecore.generator.Generator.generate(G enerator.java:528)....
Re: No getter or adder for 'genmodels' (EcoreGeneratorFragment) [message #58450 is a reply to message #58330] Tue, 14 July 2009 10:21 Go to previous message
Hi Ilyas,
I'm afraid there is either something wrong in your project setup or you
stumbled across a bug. If you don't mind please feel free and send me
your project so I can double check your settings.
Sebastian
Am 14.07.2009 13:44 Uhr, schrieb Ilyas Keser:
> </bean>
> at
> at
> at
> at
> at
> at
> at
Previous Topic:using xtext editors in a Rich Client
Next Topic:Conversion from oaw to tmf xtext - Problem with MetaModelRegistration
Current Time: Wed Oct 29 08:29:09 EDT 2025
Powered by FUDForum. Page generated in 0.04295 seconds
