Home » Language IDEs » C / C++ IDE (CDT) » CVS tags for builds and java/Exception bug in Win32ProcessEx.c
CVS tags for builds and java/Exception bug in Win32ProcessEx.c [message #58195] Wed, 15 January 2003 16:40 Go to next message
I'm trying my first CDT debug. Eclipse hangs during project build.
The visible error that java/Exception can't be found in Spawner.exec0 native
method.
I'm wondering if someone can give me some tips about the CDT builds,
CVS branches and process/relationship used?
I'm not sure which branch to use for the F2 build that I downloaded.
What are 'freeze' builds? Is there a tag or branch created for a freeze
build?
FWIW: I discovered a bug in
org.eclipse.cdt.cor.win32/library/Win32ProcessEx.c
that was obfuscating my real problem and that bug is 'almost' fixed in HEAD.
I'd like to replace that native portion of the code with the code of the
appropriate
level and see if it fixes my problem. The bug is that Win32ProcessEx uses
java/Exception instead of java/lang/Exception.
At least one of these places were changed, removing the java/Exception code
by the changes in HEAD for revision 1.6 of that file by amaglorie as part of
other changes
labeled 'fix space quotings'.
I'm running Windows XP professional.
- Eclipse Platform 2.0.2.1 build 200211071448 (WSAD v5.0.0 Build
20021125_2118)
- CDT F2 build org.eclipse.cdt-200301080308-win32_1.0.1.bin.dist.zip
"The stuff we call "software" is not like anything that human society
is used to thinking about. Software is something like a machine, and
something like mathematics, and something like language, and
something like thought, and art, and information...
but software is not in fact any of those other things."
Bruce Sterling - The Hacker Crackdown
Fred A. Kulack - IBM eServer iSeries ERP, Java DB2 access, Jdbc, JTA, etc...
IBM in Rochester, MN (Phone: 507.253.5982 T/L 553-5982)
mailto:kulack@us.ibm.com Personal: mailto:kulack@magnaspeed.net
AOL Instant Messenger: Home:FKulack Work:FKulackWrk
Re: CVS tags for builds and java/Exception bug in Win32ProcessEx.c [message #58220 is a reply to message #58195] Wed, 15 January 2003 18:10 Go to previous messageGo to next message
> appropriate
code
of
> other changes
Yes, that's correct. Fixed.
However it is not clear why it happens for you. There is only one place in
code where spawner generates Exception. It happens in case of command
buffer overflow. Buffer itself is big enough (1K), at least quite enough for
build. Could you please run the debug version I attached to this message to
see in dbmon (also attached) window what's going on? Just send me dbmon
protocol.
Thanks in advance,
Alex Chapiro.
> 20021125_2118)
etc...
  • Attachment: spawner.dll
    (Size: 52.00KB, Downloaded 142 times)
  • Attachment: dbmon.exe
    (Size: 40.00KB, Downloaded 131 times)
Re: CVS tags for builds and java/Exception bug in Win32ProcessEx.c [message #58367 is a reply to message #58220] Thu, 16 January 2003 10:20 Go to previous messageGo to next message
Thanks Alex!
There are still some instances of throw that use the incorrect exception
'java/Exception'
in HEAD.
Things do look a bit different with that version, no class not found
exception,
but this time Java.exe takes a windows exception and gets the normal windows
'java.exe has encountered a problem and needs to close' dialog.
I think I've found the problem.
Looking in HEAD, I see that the environment variable code doesn't use
copyTo() to do the required bounded copy any more, but just uses s
I suspect the size of the environment is the problem.
In the code thats part of my build, having a large environment would have
caused
the bogus java/Exception to attempt to be thrown.
In the HEAD code, having a large environment walks off the end of the
szEnvBlock
array (which is 4K).
My environment is larger than that.
> cmd /c set | wc -c
4149
This describes both the scenario in the old and the new code.
I might start with szEnvBlock being a pointer to a 4096 byte array of
automatic storage,
up to a certain point, if additional storage is needed simply allocate a
larger block,
copy the current storage to the newly allocated storage, reset the pointer
and continue.
Here's the dbmon output.
3316: ftpext: DllMain()
3316: ftpext: DllGetClassObject()
3316: ftpext: CClassFactory::CClassFactory()
3316: ftpext: CClassFactory::QueryInterface()
3316: ftpext: CClassFactory::Release()
3316: ftpext: CClassFactory::CreateInstance()
3316: ftpext: CShellExtension::CShellExtension()
3316: ftpext: CShellExtension::QueryInterface()
3316: ftpext: CShellExtension::Release()
3316: ftpext: CShellExtension::AddRef()
3316: ftpext: CClassFactory::~CClassFactory()
3316: ftpext: DllCanUnloadNow()
3316: ftpext: CShellExtension::CopyCallback()
2632: copyTo start: cmd.exe 7 866
2632: copyTo: cmd.exe 7 7
2632: copyTo start: /c 2 858
2632: copyTo: /c 2 2
2632: copyTo start: set 3 855
2632: copyTo: set 3 3
2632: C:\Program Files\IBM\WebSphere
Studio\eclipse\plugins\org.eclipse.cdt.core
..win32_1.0.1\os\win32\x86\starter.exe SABreak16112720 SAWait16112720
SATerm16112
720 cmd.exe /c set Process 852 created
2632: Process PID 852 terminated
2632: waitProcTermination: set PID 852 to 0
2632: copyTo start: c:\cygwin\bin\make 18 866
2632: copyTo: c:\cygwin\bin\make 18 18
2632: copyTo start: all 3 847
2632: copyTo: all 3 3
"Alex Chapiro" <ash371952@hotmail.com> wrote in message
news:b04nr5$f5$1@rogue.oti.com...
> > appropriate
uses
> code
part
> of
> > other changes
for
to
> protocol.
> Thanks in advance,
> Alex Chapiro.
> > 20021125_2118)
> etc...
Re: CVS tags for builds and java/Exception bug in Win32ProcessEx.c [message #58533 is a reply to message #58367] Thu, 16 January 2003 13:53 Go to previous messageGo to next message
Hi Fred,
Indeed, I lost checking of environment block overflow (it was there in the
previouse version :-)). But it doesn't explain generation of bad exception.
I found only one place in code where I generate this exception, and it is an
arguments block processing. Maybe exception happens at the second call as a
result of memory corruption..
Anyway, thanks. I fixed this problem. Attached find new test dll. Could you
please try it?
Alex
"Fred A. Kulack" <kulack@us.ibm.com> wrote in message
news:b06hks$8un$1@rogue.oti.com...
> Thanks Alex!
> 'java/Exception'
> in HEAD.
> exception,
windows
> caused
> szEnvBlock
> > cmd /c set | wc -c
> 4149
> automatic storage,
> larger block,
> and continue.
> SATerm16112
etc...
the
> > > appropriate
> uses
> > code
> part
> > of
> > > other changes
in
> for
> to
> > protocol.
> > Thanks in advance,
> > Alex Chapiro.
> > > 20021125_2118)
> > etc...
    (Size: 56.00KB, Downloaded 239 times)
Re: CVS tags for builds and java/Exception bug in Win32ProcessEx.c [message #58726 is a reply to message #58533] Fri, 17 January 2003 10:53 Go to previous message
Thanks Alex. That one works for me. I'm off to the races!
an
a
I don't think I was clear. This java/Exception usage happened only in the
original
version from cdt_1_0_1 build F2, not the fixed one that you gave me.
Thanks again for the help!
news:b06t3t$jbc$1@rogue.oti.com...
> Hi Fred,
exception.
an
a
you
> please try it?
> Alex
> > Thanks Alex!
> > 'java/Exception'
> > in HEAD.
> > exception,
> windows
have
> > caused
> > szEnvBlock
> > > cmd /c set | wc -c
> > 4149
> > automatic storage,
> > larger block,
pointer
> > and continue.
> > SATerm16112
> etc...
> the
> > > > appropriate
> > uses
java/Exception
> > > code
> > part
> > > of
> > > > other changes
place
> in
enough
> > for
message
> > to
dbmon
> > > protocol.
> > > Thanks in advance,
> > > Alex Chapiro.
> > > > 20021125_2118)
society
and
JTA,
> > > etc...
Previous Topic:Next release of CDT
Next Topic:CVS repository...
Current Time: Tue Jul 22 00:43:45 EDT 2025
Powered by FUDForum. Page generated in 0.04627 seconds
