strange behavior when defining a profile [message #576474] |
Mon, 29 January 2007 07:21 |
Rafael Chaves Messages: 362 Registered: July 2009 |
When I define the following profile named 'sample_profile':
<uml:Profile xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML"
xmi:id="_O3cisK9mEduaoJ8VsHbaPQ" name="sample_profile">
<packagedElement xmi:type="uml:Stereotype"
xmi:id="_P7ic8K9mEduaoJ8VsHbaPQ" name="sample_stereotype">
<ownedAttribute xmi:id="_Xjqr8K9mEduaoJ8VsHbaPQ" name="myProperty">
<type xmi:type="uml:PrimitiveType"
href="pathmap://UML_METAMODELS/UML.metamodel.uml#Integer"/>
</ownedAttribute>
</packagedElement>
</uml:Profile>
It results in a EPackage instance that describes the UML metamodel.
Also, if I try to apply this profile to any models I build, the model is
persisted in a way that stereotype applications are lost. The reason
seems to be that the XMI for such a model refers to stereotypes coming
from 'sample_profile' as if they were coming from 'uml':
<xmi:XMI xmi:version="2.1" (...)>
<uml:Model xmi:id="_2YHtEK9lEdu8D5FNufO7zw" name="sample_model">
</uml:Model>
<uml:sample_stereotype (...) />
</xmi:XMI>
Instead, I would expect the stereotype applications to appear as:
<sample_profile:sample_stereotype (...) />
The trigger to this problem seems to be that I am referring to a type
from the uml package (integer). If I remove the reference, the problem
goes away.
Am I doing anything wrong to cause this, or is this a bug?
Rafael
FUDForum. Page generated in 0.02702 seconds
