Home » Eclipse Projects » Eclipse Platform » Plugin directory configuration
Plugin directory configuration [message #58146] Sun, 01 June 2003 14:27 Go to next message
Originally posted by: roychous.cis.uab.edu
We want to add plugins to Eclipse IDE. But due to security restrictions we
dont have write permissions to the eclipse default plugins folder.
We need an alternative so that we can install the plugins in some temporary
folders like C:\temp\MyPlugins.This plugins should be automatically
identified while eclipse startup
just like any other plugins.So is there any way that we can configure the
location of the plugins directory?
-Suman
Re: Plugin directory configuration [message #61152 is a reply to message #58146] Tue, 03 June 2003 13:56 Go to previous messageGo to next message
Would the -plugins or -configuration command-line options give you what
you need? (See
http://127.0.0.1:3799/help/topic/org.eclipse.platform.doc.us er/tasks/running_eclipse.htm
when Eclipse is running)
Share and Enjoy,
David Saff
Re: Plugin directory configuration [message #62856 is a reply to message #61152] Wed, 04 June 2003 16:37 Go to previous message
Well I also tried out the command line option -plugins or -configuration.
But this was not solving my purpose.
However I got the solution from one of the newsgroup members.Check the link
below.
http://eclipsewiki.swiki.net/131#four
-Suman
"David Saff" <saff@mit.edu> wrote in message
news:bbinev$3ec$1@rogue.oti.com...
we
temporary
the
> you need? (See
_eclipse.htm
> Share and Enjoy,
> David Saff
Previous Topic:Renaming a file and editor
Next Topic:'Wildcard' key bindings?
Current Time: Sun Jul 13 17:13:45 EDT 2025
Powered by FUDForum. Page generated in 0.19516 seconds
