Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction
EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #58122] Thu, 19 October 2006 07:27 Go to next message
I'm moving my editing code from AdapterFactoryEditingDomain to
TransactionalEditingDomain. All my changes to the model were done with
editing domain and it's stack. After switching to TransEdDomain I got
such execptions:
java.lang.IllegalStateException: Cannot modify resource set without a
write transaction
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ssertWriting(TransactionChangeRecorder.java:295)
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ppendNotification(TransactionChangeRecorder.java:257)
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.p rocessObjectNotification(TransactionChangeRecorder.java:239)
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:195)
org.eclipse.uml2.uml.internal.impl.ElementImpl.eNotify(Eleme ntImpl.java:821)
org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(E coreEList.java:234)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(NotifyingListImpl.java:452)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(NotifyingListImpl.java:396)
at org.eclipse.emf.common.util.BasicEList.addAll(BasicEList.jav a:688)
at org.eclipse.emf.edit.command.AddCommand.doExecute(AddCommand .java:400)
org.eclipse.emf.edit.command.AbstractOverrideableCommand.exe cute(AbstractOverrideableCommand.java:128)
org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFC ommandOperation.java:116)
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:130)
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:509)
org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.exe cute(WorkspaceCommandStackImpl.java:147)
org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.exe cute(WorkspaceCommandStackImpl.java:183)
This is piece of code that makes me mad:
PrimitiveType type = UML2ModelUtil.UML_FACTORY.createPrimitiveType();
type.setName(propertyType);
type.setVisibility(VisibilityKind.PRIVATE_LITERAL);
Property newProperty = UML2ModelUtil.UML_FACTORY.createProperty();
newProperty.setVisibility(VisibilityKind.PRIVATE_LITERAL);
newProperty.setName(propertyName);
newProperty.setType(type);
EStructuralFeature eStructuralFeature=
UMLPackage.eINSTANCE.getStructuredClassifier_OwnedAttribute( );
Collection commandCollection=new ArrayList();
commandCollection.add(newProperty);
CommandParameter commandParameter = new
CommandParameter(umlClass,eStructuralFeature,commandCollecti on);
TransactionalEditingDomain editingDomain =
TransactionalEditingDomain.Registry.INSTANCE.getEditingDomai n(EDITING_DOMAIN_ID);
Command command =
editingDomain.createCommand(AddCommand.class,commandParamete r);
try {
commandStack.execute(command);
} catch (Exception exception) {
// Here I catch java.lang.IllegalStateException
What am I missing? Something specific to TransactionalEditingDomain like
"start transaction" method?
Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #58177 is a reply to message #58122] Thu, 19 October 2006 08:41 Go to previous messageGo to next message
Hi, Marcin,
It looks to me as though the code snippet below is using the wrong command
stack to execute this command. I cannot see how the 'commandStack'
variable is initialized, but I don't think it's coming from the
'editingDomain' that was initialized just a few lines previous to the
execution of the command.
Use editingDomain.getCommandStack().execute(command) and all should be well.
It is the transactional editing domain's stack that creates the
transactions for you.
HTH,
Christian
> such execptions:
> write transaction
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Command command =
> try {
> Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #58250 is a reply to message #58177] Thu, 19 October 2006 10:06 Go to previous messageGo to next message
Christian W. Damus wrote:
> Hi, Marcin,
This is extacly how I get command stack.
editingDomain is
org.eclipse.gmf.runtime.diagram.core.DiagramEditingDomainFac tory$DiagramEditingDomain
which extends TransactionalEditingDomainImpl
editingDomain.getCommandStack() is
org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl which
implements InternalTransactionalCommandStack
and InternalTransactionalCommandStack extends TransactionalCommandStack
I've found that EMF command is wrapped by
WorkspaceCommandStackImpl.execute(Command)
in EMFCommandOperation
according to EMFCommandOperation's javadoc:
* An operation that wraps an EMF {@link Command} to execute it in a
read/write
* transaction on an {@link IOperationHistory}. This class may be created
* explicitly by a client of the operation history, or it may be used
implicitly
* by executing a command on the {@link TransactionalCommandStack}.
* @author Christian W. Damus (cdamus)
I'm almost sure I should use
TransactionalCommandStack.execute(Command,Map) and pass transaction options.
What do you think? Do I follow right path?
Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #58328 is a reply to message #58250] Thu, 19 October 2006 10:17 Go to previous messageGo to next message
Hi, Marcin,
Perhaps, then, what is happening is that the umlClass object is in a
different resource set than the one associated with your editing domain?
It seems clear that the TransactionalEditingDomain in which the command
execution is starting a transaction is different from the one that is
throwing the IllegalStateException, because it has no active transaction.
With a breakpoint on the throwing of the IllegalStateException, can you
confirm whether the TransactionalEditingDomain associated with the change
recorder is the same as or different from the one associated with the
WorkspaceCommandStackImpl farther down the execution stack?
Christian
>> Hi, Marcin,
>> command
>> well. It is the transactional editing domain's stack that creates the
> editingDomain is
> read/write
> created * explicitly by a client of the operation history, or it may be
> used
> implicitly
> options.
> Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #58351 is a reply to message #58122] Thu, 19 October 2006 11:45 Go to previous messageGo to next message
Silly me:) Mystery is revealed.
I used different Editing Domain instance when reading resource. At that
moment Editing Domain is attached to the model and consumes
notifications. When command was executed with different Editing Domain
instance I got this problem. Different instance was executing command
from that one consuming notification. Obviously they don't share
transaction informations. So when it comes to TransactionChangeRecorder
it has no knowledge about transaction used to execute command (see
stacktrace). Simple change in one line fixed problem.
Solution is: Make sure you are using same Editing Domain for everything
not only for execution:)
Thanks for all of you for supporting me!:)
Marcin.
> such execptions:
> write transaction
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Command command =
> try {
> Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #58374 is a reply to message #58351] Thu, 19 October 2006 15:47 Go to previous messageGo to next message
Hi, Marcin,
I'm glad it's working for you, now!
What you have observed is that a TransactionalEditingDomain, once a resource
or object enters into its sphere of influence, "owns" that resource or
object and will not share it with other editing domains. The EMFT
Transaction world-view of editing domains is that they are closed universes
and that they do not communicate, as is commonly accepted (though not
proven) in cosmology.
That said, there is supposed to be a way to dispose of a
TransactionalEditingDomain that would "free" the resources and objects
within it. There are limitations to this that are tracked by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=161169.
Christian
> Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #58417 is a reply to message #58374] Fri, 20 October 2006 06:09 Go to previous message
> Hi, Marcin,
> Cheers,
> Christian
That helps me with my first steps in EMFT Trans world.
Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #594342 is a reply to message #58122] Thu, 19 October 2006 08:41 Go to previous message
Hi, Marcin,
HTH,
Christian
> such execptions:
> write transaction
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Command command =
> try {
> Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #594376 is a reply to message #58177] Thu, 19 October 2006 10:06 Go to previous message
> Hi, Marcin,
editingDomain is
read/write
implicitly
Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #594403 is a reply to message #58250] Thu, 19 October 2006 10:17 Go to previous message
Hi, Marcin,
Christian
>> Hi, Marcin,
>> command
> editingDomain is
> read/write
> used
> implicitly
> options.
> Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #594412 is a reply to message #58122] Thu, 19 October 2006 11:45 Go to previous message
Marcin.
> such execptions:
> write transaction
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Command command =
> try {
> Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #594422 is a reply to message #58351] Thu, 19 October 2006 15:47 Go to previous message
Hi, Marcin,
Christian
> Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #594441 is a reply to message #58374] Fri, 20 October 2006 06:09 Go to previous message
> Hi, Marcin,
> Cheers,
> Christian
Marcin.
Previous Topic:Teneo : persistence of objects URI
Next Topic:teneo - annotations in Rational Rose model - anyone?
Current Time: Mon Jul 21 21:59:26 EDT 2025
Powered by FUDForum. Page generated in 0.07607 seconds
