Home » Archived » XML Schema Definition (XSD) » How to set maxOccurs and minOccurs in a named model group
How to set maxOccurs and minOccurs in a named model group [message #58079] Thu, 24 February 2005 00:06 Go to next message
Originally posted by: mashraf.ca.ibm.com
Ed,
I am trying to generate the following named model group:
<xsd:group name="AGroup">
<xsd:sequence maxOccurs="2" minOccurs="0">
<xsd:elelemnt name="aname" type="xsd:string"/>
<!-- ... stuff ommited .. -->
</xsd:sequence>
</xsd:group>
What interface do I need to use to get the occurences as attributes of
sequence in the named model group? I know how to do that for a complex type
definition - but can't find an equivalent interface for the named model
group.
Thanks for your help.
Mahboob Ashraf
Re: How to set maxOccurs and minOccurs in a named model group [message #58206 is a reply to message #58079] Thu, 24 February 2005 06:12 Go to previous message
Mahbood,
You won't find such an API because it isn't valid to specify the
multiplicity on the model group in a model group definition (just as it
isn't valid to specify the multiplicity on a global element
declaration). It can only be specified at the point the model group
definition is reference (just with an element declaration reference to a
global element declaration). It's good to validate your schemes first...
Mahboob Ashraf wrote:
>Ed,
> </xsd:sequence>
></xsd:group>
>group.
>Mahboob Ashraf
Re: How to set maxOccurs and minOccurs in a named model group [message #594263 is a reply to message #58079] Thu, 24 February 2005 06:12 Go to previous message
Mahbood,
>Ed,
> </xsd:sequence>
></xsd:group>
>group.
>Mahboob Ashraf
Previous Topic:Test Program
Next Topic:Test Program
Current Time: Fri Jul 25 14:05:27 EDT 2025
Powered by FUDForum. Page generated in 0.03456 seconds
