CVS Repository checkout error [message #575277] |
Wed, 23 August 2006 23:47 |
Stan Rivera Messages: 36 Registered: July 2009 |
Member |
Brent,
This happened before your comments about my using the DTD for custom
objects in the VTP instead of modifying the XML editor, but I thought I'd
mentioned what happened anyway, just for future reference.
I was trying to check out the VTP plugins via the CVS repository and as it
was rebuilding the workspace, I got a dialog that was titled, "Building
workspace" with error, "Errors during build". In the "Details" section, I
see the following two times:
Errors running builder "Integrated External Tool Builder" on project
org.eclipse.vtp.source. The builder launch configuration could not be
found.
What does this mean. I tried the checkout again, this time I didn't see
this error. Does this mean the checkout was successful afterall?
I see a bunch of error in the plugin error log, things like:
!ENTRY org.eclipse.ui 4 4 2006-04-25 12:33:27.907
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-04-25 12:33:27.927
!MESSAGE java.lang.NullPointerException
!STACK 0
at
org.eclipse.wst.xml.core.internal.provisional.format.TextNod eFormatter.formatNode(TextNodeFormatter.java:60)
!ENTRY org.eclipse.wst.xml.core 4 4 2006-04-25 16:12:16.14
!MESSAGE Access is denied
!STACK 0
java.io.IOException: Access is denied
at java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.io.File.createNewFile(Unknown Source)
If I decide not to make any changes, how do I "uncheckout" and remove the
projects from my Plug-in Development Package Explorer?
Sorry so wordy, thanks.
Stan
FUDForum. Page generated in 0.03003 seconds
