Weblogic 10 integration issue in Eclipse 3.4.1 [message #58023] |
Tue, 24 February 2009 20:54  |
Dear Support,
I am working on a migration project which needs me to setup Weblogic 10
server into Eclipse 3.4.1 environment. I could successfully add the
Weblogic 10 runtime enviroment but when I proceed to create the server it
ask me to provide domain home. I create new domain using the link - Click
here to launch Configuration Wizard to create a new domain and wls.jar as
the domain template. The domain is created successfully with all the
necessary files like setDomainEnv.cmd, setDomainEnv.sh, config/config.xml
etc. but when I pass the path of this domain into the server creation step
in Eclipse it doesn't allow me to proceed. It gives below error:
The domain does not belong to the selected runtime 'BEA WebLogic Server
v10.0'. Please check bin/setDomainEnv.cmd or setDomainEnv.sh and other
scripts under the domain home.
I have cross-verified that all the above files that it indicates including
others are already present under the mydomain folder.
This issue is stopping us from migrating to Eclipse - Weblogic 10 and
hence stopping us from our development progress so kindly look into it
ASAP and provide some help.
Thanks and Regards,
Shahid P.
Re: Weblogic 10 integration issue in Eclipse 3.4.1 [message #58050 is a reply to message #58023] |
Wed, 25 February 2009 11:17  |
Shahid,
You'd be better off to ask on the WTP newsgroup, which I've added to the
"to" list of the reply. Keep in mind that you're using free open source
software so no one is under any obligation to help you...
shahid wrote:
> Dear Support,
> 10 server into Eclipse 3.4.1 environment. I could successfully add the
> it ask me to provide domain home. I create new domain using the link -
> Click here to launch Configuration Wizard to create a new domain and
> wls.jar as the domain template. The domain is created successfully
> with all the necessary files like setDomainEnv.cmd, setDomainEnv.sh,
> config/config.xml etc. but when I pass the path of this domain into
> the server creation step in Eclipse it doesn't allow me to proceed. It
> gives below error:
> Server v10.0'. Please check bin/setDomainEnv.cmd or setDomainEnv.sh
> and other scripts under the domain home.
> including others are already present under the mydomain folder.
> Thanks and Regards,
> Shahid P.
FUDForum. Page generated in 0.05460 seconds
