Home » Eclipse Projects » Nebula » Grid - double click on column header
Grid - double click on column header [message #58019] Mon, 18 August 2008 03:08 Go to next message
In my application a double click on a grid column header should open a
dialog. If I do this
grid.addMouseListener(new MouseAdapter() {
public void mouseDoubleClick(MouseEvent e) {
if (e.y < grid.getHeaderHeight()) {
// open dialog
then the dialog gets open also when I double click the column header
divider to auto size the column, which should not happen.
My current work around was to:
1) change the grid source file to have access to hoveringOnColumnResizer
private member, so in my client code I could do
&& !grid.hoveringOnColumnResizer)
// open dialog
2) change the beginning of grid.onMouseDoubleClick(MouseEvent e) method
like this
if (hoveringOnColumnResizer)
int dw = columnBeingResized.getWidth(); // added
columnBeingResized.pack();
dw -= columnBeingResized.getWidth(); // added
resizingColumn = false;
handleHoverOnColumnResizer(e.x-dw, e.y); // modified
return;
My question: is there a simpler way to achieve this and if not could we
have it implemented in the mainstream version?
Cheers
Jacek
Re: Grid - double click on column header [message #58045 is a reply to message #58019] Mon, 18 August 2008 03:52 Go to previous messageGo to next message
No not yet :-(. In my current fork I have also had this problem in my
current project where I forked the grid and what I did was to adjust the
grids mouse handlers to use the addListener()-API and customize the
detail field of the event object (holding all the booleans used internally).
Could you please file a bug report and we can discuss there how we can
achieve better event support?
Tom
Jacek Kolodziejczyk schrieb:
> Hello,
> // open dialog
> // open dialog
> like this
> return;
> Cheers
> Jacek
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Grid - double click on column header [message #58071 is a reply to message #58045] Mon, 18 August 2008 09:06 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=244422
Tom Schindl wrote:
> internally).
> Tom
>> Hello,
>> // open dialog
>> hoveringOnColumnResizer private member, so in my client code I could do
>> // open dialog
>> method like this
>> return;
>> we have it implemented in the mainstream version?
>> Cheers
>> Jacek
Re: Grid - double click on column header [message #591827 is a reply to message #58019] Mon, 18 August 2008 03:52 Go to previous message
Tom
> Hello,
> // open dialog
> // open dialog
> like this
> return;
> Cheers
> Jacek
Re: Grid - double click on column header [message #591834 is a reply to message #58045] Mon, 18 August 2008 09:06 Go to previous message
Tom Schindl wrote:
> internally).
> Tom
>> Hello,
>> // open dialog
>> // open dialog
>> method like this
>> return;
>> Cheers
>> Jacek
Previous Topic:Grid - double click on column header
Next Topic:Re: Formatted Date Control
Current Time: Wed Jul 16 20:31:43 EDT 2025
Powered by FUDForum. Page generated in 0.05472 seconds
