Home » Archived » M2M (model-to-model transformation) » collection of objects in the from of a rule
collection of objects in the from of a rule [message #57988] Thu, 16 August 2007 10:28 Go to next message
Originally posted by: youssef.srour.etu.univ-nantes.fr
I have a question concern the "from" clause of a rule.
is it possible to get back a collection of objects in the "from" of a
"rule" ?
like for example
rule a{
from b : UML!Model,
c : Set(UML!ModelElement)
-- c must be a collection of ownedElement of b( c == b.ownedElement)
to......
Re: collection of objects in the from of a rule [message #58041 is a reply to message #57988] Thu, 16 August 2007 11:05 Go to previous message
Originally posted by: quentin.glineur.obeo.fr
--------------000305060201010700040409
Content-Type: text/plain; charset=ISO-8859-15
Hi, Youssef
When you post about ATL, please put [ATL] at the beginning of the
subject. Thanks.
In fact, from your case description, I can't figure out a need of such a
collection. Indeed, the "from" part is used to filter the input model
elements in order to create the corresponding model fragments. There, c
does not bring any information about the matching. So it is not suitable
for a "from" clause.
If your need is to access this collection for the creation of your
element, simply use OCL expressions.
Quentin GLINEUR
Youssef SROUR a
Previous Topic:[ATL]Problem with transformation of a model that contains XMI href attribute
Next Topic:[ATL] Is it possible to add elements to an existing model ?
Current Time: Sun Jul 27 02:53:21 EDT 2025
Powered by FUDForum. Page generated in 0.03836 seconds
