J2ME x Java ME [message #574501] |
Sat, 24 October 2009 21:50 |
Rodolfo Messages: 4 Registered: October 2009 |
I am new withPulsar. I've just started using it when latest Ericsson's SDS release started using Pulsar.
I am not able to run Midlets and I am confused with which ME to use: J2ME or Java ME
When I used SDS 4.1 FD1, in Window -> Preferences there was only the option J2ME, but in Pulsar there is two options: J2ME or Java ME
In Java ME configuration panel I am able to set the Device Management correctly to Java ME SDK 3.0, but in J2ME conf panel I am not able to setup device management.
When I try to import the devices from WTK root directory, it does not find any device!
If I try to run any one SDS IJCU sample with Emulated Java ME Midlet, it starts running, log nothing, and die.
If I try to run any one SDS IJCU sample with Emulated J2ME Midlet, it shows the message: "Device unspecified or unavailable". This message is ok because I really could not specify the device for J2ME.
Please, I would llike to know why Pulsar have two ways to work with Midlets and I also would like to know how to make Java ME devices work.
Where I can find logs?
Any help will be really appreciated!
Thanks in advance.
My best regards,
Rodolfo
FUDForum. Page generated in 0.03602 seconds
