Home » Language IDEs » AspectJ » Capturing annotations
Capturing annotations [message #57950] Wed, 26 October 2005 08:29 Go to next message
Hi there.
New to AspectJ I did some basic examples and now I want to use it to solve
real problems ;)
For my current work I planned to tag some methods with annotations to
provide security checks without implementing those several times. Is this
a good practice at all?
First tests work so far, but I'd like to use the information in my
annotation for the advice. Example:
@Guarded("AdminsOnly")
public void whatever() {}
I can match this join point using call(@Guarded * *(..)), but I see no way
to access the string value (or other values) later.
before() : call(@Guarded * *(..)) {
// I want to access the annotation here..
Using Google I always end up with the annotation-based way of using
AspectJ, the only usable info was http://ramnivas.com/blog/index.php?p=10
- but that's only a proposal and over a year old.
Can anyone lend me a helping hand here and tell me if it's a)
viable/okay/good practice to do what I plan to do here and b) how one is
supposed to access annotations of thisJoinPoint?
Thanks in advance,
Ben
Re: Capturing annotations [message #57972 is a reply to message #57950] Wed, 26 October 2005 10:49 Go to previous message
Hi Ben,
The best place to look for things like this is the developer's notebook,
such as:
http://eclipse.org/aspectj/doc/next/adk15notebook/annotation s-pointcuts-and-advice.html
Look for the context exposure subsection - near the end of that is a
snippet that uses thisJoinPointStaticPart.getSignature() to get the
corresponding
java.lang.reflect.Method object, then you can call
getAnnotation/getAnnotations on that.
BTW, the aspectj-users list is best for language questions. This newsgroup
is primarily for AJDT-specific stuff. We do try to monitor both, but the
mailing list has a bigger audience so you might get a faster/better
response.
Matt.
Benjamin Podszun wrote:
> Hi there.
> real problems ;)
> Thanks in advance,
> Ben
Re: Capturing annotations [message #590690 is a reply to message #57950] Wed, 26 October 2005 10:49 Go to previous message
Hi Ben,
such as:
corresponding
response.
Matt.
> Hi there.
> real problems ;)
> Thanks in advance,
> Ben
Previous Topic:Capturing annotations
Next Topic:Multiple instances of the same class woven against different aspects in an Eclipse plugin [Cross-pos
Current Time: Sun Aug 31 08:59:58 EDT 2025
Powered by FUDForum. Page generated in 0.05576 seconds
