Home » Archived » Test and Performance Tools Platform (TPTP) » empty statistics view
empty statistics view [message #57928] Tue, 14 March 2006 08:40 Go to next message
Originally posted by: droelf.australia.edu
To evaluate TPTP I'm profiling a local Java application. The application
runs and terminates correctly and when I choose to output the results to a
file TPTP does indeed write values to this file. However, when I try to open
any of the views after profiling I only get empty views containing the
message "No data is available for display". Refreshing or choosing different
filters doesn't help.
But, if I import the contents of the output file that was saved to disk I
can see the results.
Now, I should be able to get the results without doing the import right? Did
anyone encounter similar problems?
This is my current config:
Eclipse 3.1.2
TPTP 3.1.0
XML Schema Infoset Model (XSD) 2.1.1
EMF SDK 2.1.2
Re: empty statistics view [message #58076 is a reply to message #57928] Tue, 14 March 2006 10:32 Go to previous messageGo to next message
Did you mean TPTP *4*.1.0? Otherwise, this combination pre-dates my
experience with TPTP...
How did you open the other views? With "Show View"? Instead, right click
on the application in the profiling window and "Open With" the view you
want instead. Or, if the view is already open, use the "Link with
Viewer" button (opposing yellow arrows). The view has to be associated
with the data being gathered in order to display it. Is lack of
association the problem you're running into?
RDS
Wolfgang wrote:
> Eclipse 3.1.2
> TPTP 3.1.0
> EMF SDK 2.1.2
Re: empty statistics view [message #58591 is a reply to message #57928] Wed, 15 March 2006 12:07 Go to previous message
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 005DDD5185257132_=
Content-Type: text/plain; charset="US-ASCII"
Note that you can't profile to a file and view the results in the
workbench *at the same time*. If you profile to a file then your views in
the workbench won't be populated. To view your profiling results in the
workbench do this:
In your profile launch configuration, click on the profiling tab -> select
the destination sub-tab -> make sure 'send profiling data to a file' is
unchecked -> switch to the overview sub-tab -> click on the add button to
create a new profiling set -> next -> select the profiling options that
you want. If you want graphical details, you have to have execution time
analysis selected and click on the 'show execution flow graphical details'
radio button -> next -> set your filterset -> finish.
Use this profiling set to profile your application.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Note that you can't profile to a file
and view the results in the workbench *at the same time*. &nbsp;If you
profile to a file then your views in the workbench won't be populated.
&nbsp;To view your profiling results in the workbench do this:</font>
<br>
<br><font size=2 face="sans-serif">In your profile launch configuration,
click on the profiling tab -&gt; select the destination sub-tab -&gt; make
sure 'send profiling data to a file' is unchecked -&gt; switch to the overview
sub-tab -&gt; click on the add button to create a new profiling set -&gt;
next &nbsp;-&gt; select the profiling options that you &nbsp;want. &nbsp;If
you want graphical details, you have to have execution time analysis selected
and click on the 'show execution flow graphical details' radio button -&gt;
next -&gt; set your filterset -&gt; finish.</font>
<br>
<br><font size=2 face="sans-serif">Use this profiling set to profile your
application.</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani </font>
--=_alternative 005DDD5185257132_=--
Previous Topic:Dnzipping the SDK download asks for a password?!?
Next Topic:Documentation on probes and otehr features?
Current Time: Tue Jul 22 02:27:20 EDT 2025
Powered by FUDForum. Page generated in 0.08745 seconds
