Home » Archived » Visual Editor (VE) » Can not add SWT library to project
Can not add SWT library to project [message #57923] |
Sat, 28 August 2004 08:58  |
I just installed a fresh eclipse 3.0 and all files linked to from here:
http://download.eclipse.org/tools/ve/downloads/drops/S-1.0M2 -200407301410/index.html
Build IDs:
eclipse - 200406251208
VE - 200407301410
EMF - 200406281448
GEF - 200406251257
Note: I have MyEclipse 3.8.1 GA installed as well.
When I try to add the SWT library to my project (as described in
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /vep-home/WebContent/docs/newAndNoteworthy/1.0.0-M2/previewi ngSWT.html)
nothing happens. Eclipse is still running, and VE presents me all Swing
and AWT controls, but the SWT controls are missing.
My .log file gives me an exception (sorry for the loooong lines):
!ENTRY org.eclipse.ui 4 4 Aug 28, 2004 14:36:07.297
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 Aug 28, 2004 14:36:07.307
!MESSAGE
org.eclipse.jem.internal.proxy.core.ProxyPlugin.findPluginJa rAndAttachedSource(Lorg/osgi/framework/Bundle;Lorg/eclipse/c ore/runtime/IPath;)[Ljava/net/URL;
!STACK 0
java.lang.NoSuchMethodError:
at org.eclipse.ve.internal.swt.SWTContainer.<init>(SWTContainer.java:56)
org.eclipse.ve.internal.swt.SWTContainerInitializer.initiali ze(SWTContainerInitializer.java:12)
I looked into my eclipse installation directory and JEM and the proxy
class seem to be there.
Any idea what is going wrong here?
Thanks in advance
Jonas
Note: 96.31% of all statistics are fiction.
Re: Can not add SWT library to project [message #57971 is a reply to message #57947] |
Sat, 28 August 2004 16:32   |
Rich Kulp wrote:
> I don't know why you are getting this. That method is definitely in that
> M2 driver.
Actually, I can find the class in one of the JAR files, and the method
seems to be there, yes.
> 1) From your workspace, select Help->About Eclipse->Feature Details and
> select the "Java EMF Model" feature, and look at the bottom of the
> dialog. The build id listed should be 200407301410
No it is not: as mentioned in my first post it is 200406281448. Which is
strange as the files (e.g. proxy.jar) in my eclipse directory are from
20040730 - which answers your second question:
> 2) go into your installation on disk to
> eclipse/plugins/org.eclipse.jem.proxy_1.0.0, in there the proxy.jar
> should be listed as 7/30/2004 2:15PM, size 73,994
It is 7/30/2004 2:16PM, size 73,994. - quite the same :-)
But your answer led me to the right direction: As I mentioned before, I
also use the MyEclipse software (a bundle of various plugins) an they also
ship JEM (and GEF, btw). The funny thing is that eclipse finds the
feature in $ECLIPSE_HOME\features, but the plugin shipped with MyEclipse
(which is installed in a different directory!) is used!?
I do not understand how eclipse finds and loads features and plugins, but
I removed the JEM and GEF plugins that came with MyEclipse and everything
seems to work (at least loading the SWT lib in VEP works, I could not yet
test all MyEclipse functionality :-).
BTW: Before the import via "Add Library..." worked, I tried it by adding
swt.jar "manually" (via "Add External JARs...") - but this did not help!
Can you shortly explain the difference between "Add Library" and "Add
External JARs"?
Anyway, case closed. Thanks for your fast help!
Kind regards,
Jonas
Re: Can not add SWT library to project [message #57995 is a reply to message #57971] |
Mon, 30 August 2004 11:00  |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
We need to know SWT is available. Also, since we need to start a remote
vm with SWT in it for us to get the pictures of what you are building,
we need to also add in the appropriate dlls. Just adding swt.jar to the
classpath doesn't do this. The SWTContainer that we wrote does all of
these things. It tells us that SWT is loaded, it tells us that we need
to add in the dlls to library path, it tells us to load the SWT palette
category.
Thanks, Rich Kulp
Re: Can not add SWT library to project [message #597901 is a reply to message #57923] |
Sat, 28 August 2004 13:46  |
M2 driver.
Thanks, Rich Kulp
Re: Can not add SWT library to project [message #597908 is a reply to message #57947] |
> M2 driver.
External JARs"?
Kind regards,
Jonas
Re: Can not add SWT library to project [message #597912 is a reply to message #57971] |
category.
Thanks, Rich Kulp
Current Time: Tue Jul 22 17:51:54 EDT 2025
Powered by FUDForum. Page generated in 0.04628 seconds
