Home » Eclipse Projects » Mylyn » Unable to login to Bugzilla
Unable to login to Bugzilla [message #5168] Fri, 29 June 2007 17:42 Go to next message
I'm using the final Eclipse 3.3 with Mylyn 2.0 and I'm trying to connect it to my company Bugzilla account. In the Task Repositories view, I can enter in the server URL and my authentication info, when I click the Validate Settings button it says "Authentication credentials are valid", but as soon as I try to do a query I get a dialog that says
Unable to login to https://<my bugzilla URL>.
log in to bugzilla
Please validate credentials via Task Repositories view.
How do I fix this issue? I've never used the Mylyn plugin before, but it seems really interesting and I'd love to get it working. Thanks for any help!
Re: Unable to login to Bugzilla [message #5237 is a reply to message #5168] Fri, 29 June 2007 19:34 Go to previous messageGo to next message
Originally posted by: rob.elves.eclipse.org
Joshua,
The Bugzilla connector does have shortcomings when dealing with some
customized Bugzilla installs. One side effect can be failure to
authenticate (or recognize successful authentication). A few things to try:
- If using a proxy ensure it is set either in your Workspace preferences
or within the Task Repository settings page.
- If the company Bugzilla site is protected via http authentication,
ensure your username and password are set in the Task Repository
settings page.
If this doesn't result in success, please open a bug report
(https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Mylyn) and we can
continue debugging there.
-Rob
> log in to bugzilla
Re: Unable to login to Bugzilla [message #6696 is a reply to message #5237] Fri, 29 June 2007 21:30 Go to previous messageGo to next message
Thank you for the feedback. I am not using a proxy, it's not using any HTTP authentication and it's not a customized Bugzilla install. It is a stock 2.22.2 installation. The only thing I can think of is that it is using a self-signed SSL certificate (HTTPS), though that will be changing shortly. If this scenario should work, then I'll file a bug report. Thanks again for your help.
Re: Unable to login to Bugzilla [message #6737 is a reply to message #5237] Mon, 02 July 2007 07:50 Go to previous message
I'm facing the same Problem. Bugzilla 2.22.1 with a self signed certificate.
There was never a question for accepting the certificate like in subclipse.
No http authentication.
Tried with and without proxy from two different places. Both resulted in an
error.
I switched in 'additional settings' to repository version 2.22
Now I changed to a free test certificate from radpidssl that is fully
functional. Still the same error.
Anonymous access to https://bugs.eclipse.org/bugs works fine.
I filled in a bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=195113
Tobias
"Robert Elves" <rob.elves@eclipse.org> schrieb im Newsbeitrag
news:f644ue$582$1@build.eclipse.org...
> Joshua,
> try:
> ensure your username and password are set in the Task Repository settings
> page.
> -Rob
>> but as soon as I try to do a query I get a dialog that says Unable to
>> login to https://&lt;my bugzilla URL&gt;. log in to bugzilla
>> help!
Re: Unable to login to Bugzilla [message #569043 is a reply to message #5168] Fri, 29 June 2007 19:34 Go to previous message
Joshua,
settings page.
-Rob
> Unable to login to https://&lt;my bugzilla URL&gt;.
> log in to bugzilla
Re: Unable to login to Bugzilla [message #569164 is a reply to message #5237] Fri, 29 June 2007 21:30 Go to previous message
Re: Unable to login to Bugzilla [message #569353 is a reply to message #5237] Mon, 02 July 2007 07:50 Go to previous message
error.
Tobias
> Joshua,
> try:
> page.
> -Rob
>> help!
Previous Topic:Mylyn iCal connector
Next Topic:Supporting new mylyn connector?
Current Time: Sun Aug 31 17:16:57 EDT 2025
Powered by FUDForum. Page generated in 0.50503 seconds
