Home » Language IDEs » PHP Development Tools (PDT) » Debugger Setup , Help Needed
Debugger Setup , Help Needed [message #57840] Fri, 12 October 2007 03:33 Go to next message
Originally posted by: venu.neureol.com
I have installed the all in one package PDT 1.0. I have XAMP installed on my
Windows XP PC.
I have tried to install the Zend Debugger but unable to make it run. (Precisely
I am unable to set breakpoints and let the code stop there.)
Has someone successfully installed successfully, Appreciate your help and any
instructions.
Cheers
...venu
Re: Debugger Setup , Help Needed [message #57890 is a reply to message #57840] Fri, 12 October 2007 04:40 Go to previous message
have you allready found the following tutorials?
http://www.thierryb.net/pdtwiki/index.php?title=Using_PDT_:_ Installation_:_Installing_the_Zend_Debugger
http://www.thierryb.net/pdtwiki/index.php?title=Using_PDT_:_ User_Guide_:_PHP_Source_Level_Debugging#Debugging_with_Zend_ Debugger
Also notice that you edit not the /xampp/php/php.ini but the
/xampp/apache/bin/php.ini described in the tutorial.
I also used the configuration with ZendManager and prepared
the downloaded ZendDebugger directory like the one of the
ZendOptimizer:
/xampp/php/ZendDebugger
|- php-4.2.0
|- php-4.2.x
There I copy the corresponding ZendDebugger.dlls.
My configuration:
[Zend]
;zend_extension_ts =
"C:\Programme\xampp\php\ext\php_xdebug-2.0.0-5.2.2.dll" ;XDEBUG
zend_extension_ts =
" C:\Programme\xampp\php\zendOptimizer\lib\ZendExtensionManage r.dll "
zend_extension_manager.optimizer_ts =
"C:\Programme\xampp\php\zendOptimizer\lib\Optimizer"
zend_extension_manager.debug_server_ts =
"C:\Programme\xampp\php\ZendDebugger"
;zend_extension_ts = "C:\Programme\xampp\php\ext\ZendDebugger.dll"
zend_optimizer.enable_loader = 0
zend_optimizer.optimization_level=15
zend_debugger.expose_remotely=allowed_hosts
zend_debugger.allow_hosts=127.0.0.1, 192.168.0.2
Hope this will help,
T.Gau
> installed on my Windows XP PC.
> (Precisely I am unable to set breakpoints and let the code stop there.)
> help and any instructions.
> Cheers
> ..venu
Previous Topic:Eclipse and PHP
Next Topic:Using PDT as CLI-only, with no web server?
Current Time: Sat Jul 26 18:00:46 EDT 2025
Powered by FUDForum. Page generated in 0.15613 seconds
