Home » Modeling » TMF (Xtext) » Left recursion: from binary to n-ary operations
Left recursion: from binary to n-ary operations [message #57815] Mon, 13 July 2009 14:46 Go to next message
Originally posted by: c.krause.cwi.nl
Hi all,
this is a grammar for arithmetical expressions, as suggested in a post
some weeks ago (thank you Sven, by the way):
PlusOperation returns Expression:
MultiplyOperation ({BinaryOp.left=current} operator=('+'|'-')
right=MultiplyOperation)*;
MultiplyOperation returns Expression:
PrimaryExpression ({BinaryOp.left=current} operator=('*'|'/')
right=PrimaryExpression)*;
PrimaryExpression returns Expression:
NumberLiteral |
'(' PlusOperation ')';
NumberLiteral :
value=INT;
If I uderstand it correctly, this avoids the left recursion and nicely
handles the priority of the operations. What I would like to do now is
to go from binary operations to n-ary. My plan would be to:
* make separate rules for +,-,*,/, and then
* to use something like {NaryOp.members += current}
Does that sound like a good plan or did I misunderstood something? Any
suggestions are of course more than welcome.
Christian Krause,
CWI Amsterdam
Re: Left recursion: from binary to n-ary operations [message #57912 is a reply to message #57815] Mon, 13 July 2009 15:19 Go to previous messageGo to next message
What exactly do you mean by n-ary?
A fixed size of operands greater than two (e.g. "foo ? bar : baz") or an
arbitrary concatenation of operations ending up as one model element
with any number of operands (like '1 + 2 + 3 + 4 + ...')?
Sven
Christian Krause schrieb:
> Hi all,
> NumberLiteral |
> NumberLiteral :
> value=INT;
> Cheers,
> Christian Krause,
> CWI Amsterdam
Re: Left recursion: from binary to n-ary operations [message #57936 is a reply to message #57912] Mon, 13 July 2009 15:48 Go to previous messageGo to next message
I see that was a bit fuzzy. I mean an arbitrary length >= 2 (so at least
one occurrence of the (same) operand).
Christian
> Cheers,
> Sven
>> Hi all,
>> NumberLiteral |
>> NumberLiteral :
>> value=INT;
>> Cheers,
>> Christian Krause,
>> CWI Amsterdam
Re: Left recursion: from binary to n-ary operations [message #57984 is a reply to message #57936] Mon, 13 July 2009 16:03 Go to previous messageGo to next message
This could be written like this:
NaryOp returns Expression :
Operand ({NaryOp.operands+=current} '+' operands+=Operand ('+'
operands+=Operand)*)?;
Sven
> Cheers,
> Christian
>> an arbitrary concatenation of operations ending up as one model
>> element with any number of operands (like '1 + 2 + 3 + 4 + ...')?
>> Cheers,
>> Sven
>>> Hi all,
>>> post some weeks ago (thank you Sven, by the way):
>>> NumberLiteral |
>>> NumberLiteral :
>>> value=INT;
>>> nicely handles the priority of the operations. What I would like to
>>> do now is to go from binary operations to n-ary. My plan would be to:
>>> Any suggestions are of course more than welcome.
>>> Cheers,
>>> Christian Krause,
>>> CWI Amsterdam
Re: Left recursion: from binary to n-ary operations [message #58033 is a reply to message #57984] Mon, 13 July 2009 16:12 Go to previous messageGo to next message
Dear Sven,
thank you for this quick and detailed help. I really appreciate it. I
think I know more or less how to go from here.
Christian
PS: I guess you don't happen to know whether Itemis is planning to open
an office in Berlin..
> Sven
>> least one occurrence of the (same) operand).
>> Cheers,
>> Christian
>>> Cheers,
>>> Sven
>>>> Hi all,
>>>> NumberLiteral |
>>>> NumberLiteral :
>>>> value=INT;
>>>> Cheers,
>>>> Christian Krause,
>>>> CWI Amsterdam
Re: Left recursion: from binary to n-ary operations [message #58058 is a reply to message #58033] Mon, 13 July 2009 17:23 Go to previous messageGo to next message
Since it might be useful for others as well, this is the grammar I'm
using now:
Addition returns Expression:
Subtraction ( {Addition.operands += current} ('+' operands +=
Subtraction)+)?;
Subtraction returns Expression:
Multiplication ( {Subtraction.operands += current} ('-' operands +=
Multiplication)+)?;
Multiplication returns Expression:
Division ( {Multiplication.operands += current} ('*' operands +=
Division)+)?;
Division returns Expression:
Operation ( {Division.operands += current} ('/' operands += Operation)+)?;
Literal | '(' Addition ')';
Literal:
Constant | Variable;
Variable returns Variable:
name=ID;
Constant returns Constant:
value=INT;
The only wrong thing now is that 'operands' should be an attribute of a
common superclass 'Operation', but this shouldn't be too difficult.
Anyway, thanks again for the help.
Christian
Christian Krause wrote:
> Dear Sven,
> Cheers,
> Christian
>> Sven
>>> Cheers,
>>> Christian
>>>> or an arbitrary concatenation of operations ending up as one model
>>>> Cheers,
>>>> Sven
>>>>> Hi all,
>>>>> NumberLiteral |
>>>>> NumberLiteral :
>>>>> value=INT;
>>>>> Cheers,
>>>>> Christian Krause,
>>>>> CWI Amsterdam
Re: Left recursion: from binary to n-ary operations [message #58158 is a reply to message #58058] Tue, 14 July 2009 04:39 Go to previous messageGo to next message
Hi Christian,
I think the mathmatical operators below are binary.
IMHO it is best practice to have them as such, because it makes it
simpler to work on them later on.
Why do you want them to be n-ary?
Sven
> using now:
> Subtraction)+)?;
> Multiplication)+)?;
> Division)+)?;
> Operation)+)?;
> Literal:
> name=ID;
> value=INT;
> Cheers,
> Christian
>> Dear Sven,
>> Cheers,
>> Christian
>> open an office in Berlin..
>>> Sven
>>>> Cheers,
>>>> Christian
>>>>> Cheers,
>>>>> Sven
>>>>>> Hi all,
>>>>>> NumberLiteral |
>>>>>> NumberLiteral :
>>>>>> value=INT;
>>>>>> to do now is to go from binary operations to n-ary. My plan would
>>>>>> be to:
>>>>>> Cheers,
>>>>>> Christian Krause,
>>>>>> CWI Amsterdam
Re: Left recursion: from binary to n-ary operations [message #58281 is a reply to message #58158] Tue, 14 July 2009 05:57 Go to previous message
Hi Sven,
I understand your concern. I think in the end I will have only addition
and multiplication n-ary and the other two binary. I want to use the
associativity of _+_ and _*_ to simplify the model. If someone enters
(a+(b+c)) I can do a very simple model transformation and write it as
(a+b+c).
Christian
> Hi Christian,
> Cheers,
> Sven
>> using now:
>> Subtraction)+)?;
>> += Multiplication)+)?;
>> Division)+)?;
>> Operation)+)?;
>> Literal:
>> name=ID;
>> value=INT;
>> a common superclass 'Operation', but this shouldn't be too difficult.
>> Cheers,
>> Christian
>>> Dear Sven,
>>> Cheers,
>>> Christian
>>>>> Cheers,
>>>>> Christian
>>>>>> Cheers,
>>>>>> Sven
>>>>>>> Hi all,
>>>>>>> NumberLiteral |
>>>>>>> NumberLiteral :
>>>>>>> value=INT;
>>>>>>> be to:
>>>>>>> something? Any suggestions are of course more than welcome.
>>>>>>> Cheers,
>>>>>>> Christian Krause,
>>>>>>> CWI Amsterdam
Previous Topic:Modeling predefined and custom commands with same prefix
Next Topic:[xText] Pulling up features into common super class
Current Time: Sun Jul 13 20:39:09 EDT 2025
Powered by FUDForum. Page generated in 0.08528 seconds
