Home » Eclipse Projects » GEF » PRB with Example under Linux/GTK
PRB with Example under Linux/GTK [message #57800] Fri, 24 January 2003 04:25 Go to next message
I've got a problem with the logic example using Eclipse 2.0.2 (stable) and
GEF I20030121 under Linux/GTK2: I can't add new components from the palette
(but I can perfectly move around existing components on the editor - once
brought onto the editor via the 4bit-adder wizard).
Did I miss something or did I run into a bug?
Thanks in advance,
Flo
Re: PRB with Example under Linux/GTK [message #57847 is a reply to message #57800] Fri, 24 January 2003 13:24 Go to previous messageGo to next message
Are you dragging and dropping the items from the palette?
Pratik Shah
"contus" <contus@web.de> wrote in message news:b0qvlb$kcp$1@rogue.oti.com...
palette
> Thanks in advance,
> Flo
Re: PRB with Example under Linux/GTK [message #58215 is a reply to message #57800] Mon, 27 January 2003 09:16 Go to previous messageGo to next message
Originally posted by: hudsonr.us.i_b_m.com
SWT/GTK does not support native drag-and-drop in 2.0.2.
palette
> Thanks in advance,
> Flo
Re: PRB with Example under Linux/GTK [message #62495 is a reply to message #57847] Thu, 06 February 2003 09:31 Go to previous messageGo to next message
yes.
Florian Dummert
> Pratik Shah
>> and GEF I20030121 under Linux/GTK2: I can't add new components from the
> palette
>> Thanks in advance,
>> Flo
Re: PRB with Example under Linux/GTK [message #62513 is a reply to message #58215] Thu, 06 February 2003 09:32 Go to previous messageGo to next message
Is it a difference between dragging and dropping an item from the palette
(which does not work) and dragging and dropping an item within the editor
(which works perfectly)?
Flo
> palette
>> Thanks in advance,
>> Flo
Re: PRB with Example under Linux/GTK [message #62583 is a reply to message #62513] Thu, 06 February 2003 09:35 Go to previous message
"contus" <contus@web.de> wrote in message news:b1tqa2$t4t$2@rogue.oti.com...
Yes, inside the editor is a single SWT Canvas. We use mouse listeners to
drag the items. If we used native DND inside the editor, we would not be
able to control the Cursor.
> Flo
> > palette
once
> >> Thanks in advance,
> >> Flo
Previous Topic:GEF & Debugging
Next Topic:direct-graph layout
Current Time: Tue Jul 22 19:13:03 EDT 2025
Powered by FUDForum. Page generated in 0.04511 seconds
