Home » Language IDEs » PHP Development Tools (PDT) » Using PDT as CLI-only, with no web server?
Using PDT as CLI-only, with no web server? [message #57767] Thu, 11 October 2007 13:50 Go to next message
Originally posted by: shiva.io.com
Is it possible to use PDT solely with PHP's CLI executable (I'm using
WinXP) instead of having to install a web server>
Earl Cooley III (shiva@io.com)
Re: Using PDT as CLI-only, with no web server? [message #57792 is a reply to message #57767] Thu, 11 October 2007 15:53 Go to previous messageGo to next message
Yes. You may debug scripts within running web servers or debug/run cli
scripts.
Re: Using PDT as CLI-only, with no web server? [message #57816 is a reply to message #57792] Thu, 11 October 2007 19:41 Go to previous messageGo to next message
> scripts.
Since it appears that this outputs raw text to the console and not the
Browser Output or Internal Web Browser views, it looks like I'm going to
have to try to figure out how to use the Eclipse WST Preview Server. Ah,
well....
Re: Using PDT as CLI-only, with no web server? [message #57916 is a reply to message #57816] Fri, 12 October 2007 05:52 Go to previous messageGo to next message
>> scripts.
> well....
The reason you get raw text may be that you configured the php-cli.exe
as the PHP executable in the PDT configuration. You can try to select
the no CLI version of PHP executable to obtain response in the browser
output.
Anyway, I think that you don't would find troubles installing a web
server in WinXP, there are alot of packages that makes installation of
Apache+PHP be an easy job. One example is easyphp, that you can find in
http://www.easyphp.org.
Re: Using PDT as CLI-only, with no web server? [message #57940 is a reply to message #57816] Fri, 12 October 2007 06:47 Go to previous messageGo to next message
I'm using PDT + ZendDebugger with XAMPP and it works quite well. For
configuring ZendDebugger see:
news://news.eclipse.org:119/fenc3s$dv8$1@build.eclipse.org
T.Gau
>> scripts.
> well....
Re: Using PDT as CLI-only, with no web server? [message #57963 is a reply to message #57940] Fri, 12 October 2007 06:55 Go to previous message
Hm, don't know wether the news:// link works. So alternatively search
for: "Debugger Setup , Help Needed"
T. Gau schrieb:
> T.Gau
Previous Topic:Debugger Setup , Help Needed
Next Topic:Re: There are no projects that can be added or removed from the server.
Current Time: Mon Jul 21 21:44:44 EDT 2025
Powered by FUDForum. Page generated in 0.06300 seconds
