Home » Language IDEs » C / C++ IDE (CDT) » C++ parser stability & completeness
C++ parser stability & completeness [message #57656] Fri, 10 January 2003 08:14 Go to next message
Originally posted by: scott.finnie.virgin.net
[Apologies if this is answered elsewhere, pointers appreciated if so].
I'm considering some C++ analysis tools, so require access to parse
trees --> am interested in whether the cdt parser will fit the bill.
For example,
. does it parse all c++ (e.g. method bodies as well as declarations,
templates)?
. Is the parse tree structure documented? If so, where?
. How to access the parse tree? (e.g. API?)
. any platform limitations? (e.g. windows-isms not handled?)
Many thanks.
- Scott.
Re: C++ parser stability & completeness [message #57681 is a reply to message #57656] Fri, 10 January 2003 08:17 Go to previous messageGo to next message
Hi!
My small experiments in this sphere revealed that C++ code parsing in CDT
is not very complicated and I think there are no any documentation on it.
Source code you can find in org.eclipse.cdt.core plugin in 2 packages:
org.eclipse.cdt.internal.parser and
org.eclipse.cdt.internal.parser.generated
May I be curious about your interest in C++ analysis tools if it is not a
secret?
Igor S. Zamyatin
Interstron Ltd.
> For example,
> templates)?
> Many thanks.
> - Scott.
Re: C++ parser stability & completeness [message #57813 is a reply to message #57681] Sat, 11 January 2003 13:20 Go to previous messageGo to next message
If you need more data you may want to look
at gccxml http://www.gccxml.org
this is a gcc hack that dumps xml for the
the symbols in the code from the symbol table
Mike
"Igor S. Zamyatin" <isz@interstron.ru> wrote in message
news:avmh5j$vdo$1@rogue.oti.com...
> Hi!
> secret?
> Igor S. Zamyatin
> Interstron Ltd.
> > For example,
> > templates)?
> > Many thanks.
> > - Scott.
Re: C++ parser stability & completeness [message #61089 is a reply to message #57656] Mon, 03 February 2003 20:02 Go to previous message
> For example,
> templates)?
At this point, no.
The C/C++ parser in the CDT is incomplete, the first try
was/is base on the public one available in JavaCC.
> Many thanks.
> - Scott.
Previous Topic:Code Completion on W2K
Next Topic:cygwin update...build command
Current Time: Sun Jul 27 03:02:10 EDT 2025
Powered by FUDForum. Page generated in 0.04811 seconds
