Home » Language IDEs » Java Development Tools (JDT) » [ANN] release 1.3 of the metrics plugin is out
[ANN] release 1.3 of the metrics plugin is out [message #57622] Sat, 14 June 2003 16:06 Go to next message
http://metrics.sourceforge.net
I just released version 1.3, with the following changes:
* Use JDBM instead of Prevayler, resulting in a dramatic reduction of memory
footprint for large projects,
* Customizable colors (I had no idea how important this can be in the
context of OSs color themes :-),
* Checked menu item in projects popup,
* Now properly renders and exports the default package as "(default
package)" instead of an empty string,
* various bugfixes and performance enhancements
Enjoy,
Frank
Re: [ANN] release 1.3 of the metrics plugin is out [message #58304 is a reply to message #57622] Mon, 16 June 2003 05:21 Go to previous messageGo to next message
Originally posted by: joerg.von.frantzius.artnology.nospam.com
As a potential user (the plugin is still calculating the metrics for my
project), I'd like to give a first feature request. Several other people
have already been looking for something that indicates "use counts" of
packages, classes and public members. That would make it really easier
to clean up a project.
Mabe it's worth a separate plugin, but wouldn't it be nice to see those
"use counts" or a gaphical decorator for 0 uses of a package or class in
the the packages view?
>Enjoy,
>Frank
Re: [ANN] release 1.3 of the metrics plugin is out [message #58869 is a reply to message #58304] Mon, 16 June 2003 18:21 Go to previous messageGo to next message
At the package level that would be the afferent coupling metric already
provided.
In case of problematic (cyclic) package dependencies, the dependency graph
view can expand the detail to the class level.
Frank
"Joerg von Frantzius" <joerg.von.frantzius@artnology.nospam.com> wrote in
message news:bck20i$nef$1@rogue.oti.com...
memory
> >Enjoy,
> >Frank
Re: [ANN] release 1.3 of the metrics plugin is out [message #59139 is a reply to message #58304] Tue, 17 June 2003 09:23 Go to previous messageGo to next message
Originally posted by: dcorbin.imperitek.com
This sounds like a find idea, but I'd want it to incorporate support for
fully qualified class path references from XML files as a usage.
Otherwise, many of the classes in Struts package might show up as 'un
referenced'.
David
>> memory
>> Enjoy,
>> Frank
Re: [ANN] release 1.3 of the metrics plugin is out [message #59480 is a reply to message #57622] Tue, 17 June 2003 13:10 Go to previous messageGo to next message
Originally posted by: bangham.neocera.com
I just installed this plug in and I think it's great! I'm not able to get
the dependency view to work though - it's blank. I select my root project,
then Window->Show View->Other...->Dependency Graph View, and a window comes
up but it's blank.
Any suggestions?
Thank you,
Mike.
"Frank Sauer" <sauerf@yahoo.com> wrote in message
news:bcfvjj$cqg$1@rogue.oti.com...
memory
> Enjoy,
> Frank
Re: [ANN] release 1.3 of the metrics plugin is out [message #59529 is a reply to message #57622] Tue, 17 June 2003 14:30 Go to previous messageGo to next message
Originally posted by: david.purple-sunshine.de
Hi Frank,
Wow! Congratulations to that good work! Eclipse has thrown JBuilder from
my desktop, and now it's more and more coming at Together (I'm not too
happy with the UML support, yet, though... guess that's Together's last
chance) ;-)
This plugin rocks!!!
david
Auch das geht vorüber. (Sufi-Weisheit)
Holger (David) Wagner Tel: +49 (89) 890 50 962
Dewetstrasse 1 Mobil: +49 (177) 274 12 45
D-80807 München Fax: +49 (177) 992741245
Re: [ANN] release 1.3 of the metrics plugin is out [message #59905 is a reply to message #59480] Tue, 17 June 2003 23:05 Go to previous messageGo to next message
You need to start it from the other view's (with the tree table) toolbar.
I could not figure out how *not* to list the view in the view selection
dialog :-(
Frank
"Michael" <bangham@neocera.com> wrote in message
news:bcni89$puu$1@rogue.oti.com...
project,
comes
> up but it's blank.
> Any suggestions?
> Thank you,
> Mike.
> memory
> > Enjoy,
> > Frank
Re: [ANN] release 1.3 of the metrics plugin is out [message #60350 is a reply to message #59905] Wed, 18 June 2003 09:22 Go to previous messageGo to next message
Thank you - that did it. This is a great tool, thank you.
Mike
news:bcol8l$mef$1@rogue.oti.com...
> dialog :-(
> Frank
get
> project,
> comes
> > up but it's blank.
> > Any suggestions?
> > Thank you,
> > Mike.
> > memory
> > > Enjoy,
> > > Frank
Re: [ANN] release 1.3 of the metrics plugin is out [message #60374 is a reply to message #59905] Wed, 18 June 2003 09:36 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
Frank,
I don't know of a way to make it not show up in the views menu (not sure
that's a good idea really) but instead of a blank window, how about you
display a message there like the Hierarchy window does. In that view, if no
type is selected it says:
"To display the type hierarchy, select a type (for example in the outline
view or in ethe editor), and select the 'Open Type Hierarchy' menu option.
Alternatively, you can drag and drop an element (e.g. project, package,
type) onto this view."
I found the blank window confusing too so I think this would help.
--Ed
> dialog :-(
Re: [ANN] release 1.3 of the metrics plugin is out [message #60398 is a reply to message #60374] Wed, 18 June 2003 09:47 Go to previous messageGo to next message
Hey,
I had the same problem when starting to use Frank's plugin. What a brilliant
solution Ed.
Best regards.
"Ed Burnette" <ed.burnette@REMOVE.THIS.sas.com> wrote in message
news:bcpptm$m4j$1@rogue.oti.com...
> Frank,
no
> Cheers,
> --Ed
Re: [ANN] release 1.3 of the metrics plugin is out [message #61171 is a reply to message #60374] Wed, 18 June 2003 14:11 Go to previous message
I like it!
Frank
> Frank,
no
> Cheers,
> --Ed
toolbar.
> > dialog :-(
Previous Topic:Running unit tests from org.eclipse.jdt.ui.tests.refactoring project
Next Topic:running eclipse builds headless?
Current Time: Sat Jul 26 06:08:40 EDT 2025
Powered by FUDForum. Page generated in 0.06982 seconds
