Home » Language IDEs » Java Development Tools (JDT) » [REQ] JSP development
[REQ] JSP development [message #455] Thu, 17 April 2003 12:30 Go to next message
Originally posted by: tud67.yahoo.it
which are the plugins to develop JSP pages with Tomcat, debugging and syntax
highlighting?
Tud
Re: [REQ] JSP development [message #467 is a reply to message #455] Thu, 17 April 2003 13:44 Go to previous messageGo to next message
Originally posted by: reply.group.com
http://sourceforge.net/projects/solareclipse/
http://www.sysdeo.com/eclipse/tomcatPlugin.html
"Tud" <tud67@yahoo.it> wrote in message news:b7mk9r$f9j$1@rogue.oti.com...
syntax
> highlighting?
> Thanks
> Tud
Re: [REQ] JSP development [message #494 is a reply to message #455] Fri, 18 April 2003 00:00 Go to previous messageGo to next message
The upcoming release of MyEclipse J2EE Tools will include JSP features such
as:
- color syntax highlighting
- formatting
- JSP validation and error marking
- java scriptlet completion
- jsp and html tag completion
- native JSP source debugger for Weblogic, JBoss, and Tomcat
www.myeclipseide.com
Wayne
syntax
> highlighting?
> Thanks
> Tud
Re: [REQ] JSP development --> not supported within Eclipse [message #518 is a reply to message #467] Fri, 18 April 2003 10:15 Go to previous messageGo to next message
Originally posted by: Hama.web.de
Hi KV,
please correct me, but the support for jsp's doesn't work. not with
solareclipse, not with lomboz, neither with bejy ,......
i tried them all and you only get a wizard for creation of such file types.
not any plugin supports the code compl. or syntax checking.
am i right ?
Hama
> > Hi,
> syntax
> > highlighting?
> > Thanks
> > Tud
Re: [REQ] JSP development --> not supported within Eclipse [message #545 is a reply to message #518] Fri, 18 April 2003 12:33 Go to previous messageGo to next message
Originally posted by: puritan4.yahoo.com
This is not quite true. Both Lomboz and BEJY provide code completion,
etc. I have never been able to get Lomboz working consistantly (I think
it requires Tomcat or some other server installed for completion to work).
Code completion does work in BEJY, you just have to configure the project
and plugin correctly, then enable the BEJY server see the home page for
instructions:
http://www.bejy.org/index.html
Sam.
Hama wrote:
> Hi KV,
> am i right ?
> Hama
> > > Hi,
> > syntax
> > > highlighting?
> > > Thanks
> > > Tud
Re: [REQ] JSP development --> not supported within Eclipse [message #998 is a reply to message #545] Sun, 20 April 2003 18:01 Go to previous messageGo to next message
Originally posted by: hama.yahoo.fr
Hi sam,
> instructions:
this is what \'s the problem. i have to configure MY project according to
structure of a plugin to be able to have simple help (like JSP code compl.)
which is provided by all the other IDE\'s, like IDEA !!! or netbeans.
thats why we throw eclipse away after trying to swith to that ide.
or EJB support,....
the plugin framework is a great idea, and i would like to get a plugin
with that i can do that development and that devel..... but what i dont
want to do, is to modify my project(s) structure just for e.g. jsp
suppport.... ;(
do you see any upcoming improvments for that issue ?
> Sam.
> Hama wrote:
> > Hi KV,
> > please correct me, but the support for jsp\'s doesn\'t work. not with
> > am i right ?
> > Hama
> > > \"Tud\" <tud67@yahoo.it> wrote in message
> > > > Hi,
> > > syntax
> > > > highlighting?
> > > > Thanks
> > > > Tud
Re: [REQ] JSP development --> not supported within Eclipse [message #1025 is a reply to message #998] Sun, 20 April 2003 22:47 Go to previous messageGo to next message
You could take a look at WebSphere Studio Site Developer.
http://www-3.ibm.com/software/awdtools/studiositedev/
Peter
hama wrote:
> Hi sam,
>>instructions:
> or EJB support,....
> suppport.... ;(
>>Sam.
>>Hama wrote:
>>>Hi KV,
>>>am i right ?
>>>Hama
>>>>>Hi,
>>>>syntax
>>>>>highlighting?
>>>>>Thanks
>>>>>Tud
Re: [REQ] JSP development --> not supported within Eclipse [message #1239 is a reply to message #998] Mon, 21 April 2003 11:57 Go to previous messageGo to next message
Hi Hama,
I totally understand your frustration with trying to develope JSP with
Eclipse, I feel the same way. We should not have to change a project
sturcture just to make an editor work. The lack of a good, complete, JSP
editor is one of the biggest weaknesses of Eclipse.
Short of buying from IBM, I don't see any near term solution. Sad when
you consider the amount of JSP development going on. Perhaps someone will
(or is?) addressing the problem.
Sam.
hama wrote:
> Hi sam,
> > instructions:
> or EJB support,....
> suppport.... ;(
> > Sam.
> > Hama wrote:
> > > Hi KV,
types.
> > > am i right ?
> > > Hama
> > > > > Hi,
> > > > syntax
> > > > > highlighting?
> > > > > Thanks
> > > > > Tud
Re: [REQ] JSP development --> not supported within Eclipse [message #1264 is a reply to message #998] Mon, 21 April 2003 14:00 Go to previous messageGo to next message
I have felt the same frustration with the jsp plugins I have tried. I am
resigned to wait for native jsp support in the 2.2 release; it's the
second JDT feature on the 2.2 Draft Plan:
http://www.eclipse.org/eclipse/development/eclipse_project_p lan_2_2.html#JDT
Hope this cheers you up a little. Fortunately for me I don't have to work
with jsp too frequently anymore. If I did, I would go back to using Idea.
--AK
> or EJB support,....
> suppport.... ;(
Re: [REQ] JSP development --> not supported within Eclipse [message #1308 is a reply to message #998] Mon, 21 April 2003 14:06 Go to previous messageGo to next message
--AK
> or EJB support,....
> suppport.... ;(
Re: [REQ] JSP development --> not supported within Eclipse [message #1725 is a reply to message #1239] Mon, 21 April 2003 20:12 Go to previous messageGo to next message
Your suggestion to buy IBM does not eliminate potential project
restructuring requirements to work with WSAD. I have worked on a number of
projects where Eclipse and/or WSAD is used and am interested in learning
more about what type of project structures you employ that can not be mapped
onto an Eclipse 2.1 project model. For discussion purposes can you provide
an example or two?
Just curious.
Wayne
"Sam" <puritan4@yahoo.com> wrote in message
news:b814d3$evn$1@rogue.oti.com...
> Hi Hama,
> Sam.
> hama wrote:
> > Hi sam,
project
for
> > > instructions:
to
compl.)
> > or EJB support,....
> > suppport.... ;(
> > > Sam.
> > > Hama wrote:
> > > > Hi KV,
with
> types.
> > > > am i right ?
> > > > Hama
> > > > > > Hi,
debugging and
> > > > > syntax
> > > > > > highlighting?
> > > > > > Thanks
> > > > > > Tud
Re: [REQ] JSP development --> not supported within Eclipse [message #1749 is a reply to message #1725] Tue, 22 April 2003 08:29 Go to previous message
Originally posted by: hama.yahoo.com
Hi Wayne,
on all the projects with eclipse , have you developed with JSP's ? if yes,
how you set up the development of this kind of files ?
text editor based ?
every good IDE (Intellij or NETBEANS)has JSP support and are in some cases
also for free.
sad about that missing aspect , i go back to intellij,
Hama
> an example or two?
> Just curious.
> Wayne
> > Hi Hama,
> > Sam.
> > hama wrote:
> > > Hi sam,
> project
> for
> > > > instructions:
> to
> compl.)
> > > or EJB support,....
> > > suppport.... ;(
> > > > Sam.
> > > > Hama wrote:
> > > > > Hi KV,
> with
> > types.
> > > > > am i right ?
> > > > > Hama
> > > > > > > Hi,
> debugging and
> > > > > > syntax
> > > > > > > highlighting?
> > > > > > > Thanks
> > > > > > > Tud
Previous Topic:Re: src.zip
Next Topic:Completion of variables
Current Time: Tue Jul 22 01:41:39 EDT 2025
Powered by FUDForum. Page generated in 0.05289 seconds
