Home » Language IDEs » ServerTools (WTP) » Re: Problem with code assist
Re: Problem with code assist [message #57582] Thu, 23 December 2004 10:56 Go to next message
Originally posted by: rcw3.NO_SPAM_levelpath.com
Ok… I'll answer my own question. I verified that I'm opening the jsp file with the JSP Source editor – and discovered how to do that (right clicking the file) and how to setup more permanent editor associations (preferences -> general).
Although, I now need to move my question to a different audience - since it appears that all of my code completion has stopped working (i.e. .java files as well).
Rich Wardwell
rich@levelpath.com
________________________________________
Posted At: Thursday, December 23, 2004 9:56 AM
Posted To: Deleted Items
Conversation: Problem with JSP Source Page Editor / code assist
Subject: Re: Problem with JSP Source Page Editor / code assist
Ahh… interesting – so how can I verify what editor Eclipse is trying to use? Presuming this is the issue, how can I instruct Eclipse to associate properly with the JSP editor?
Thanks for the help!
Rich Wardwell
rich@levelpath.com
From: Gael [mailto:gael.billard@jwaretechnologies.com]
Posted At: Thursday, December 23, 2004 9:54 AM
Posted To: eclipse.webtools
nntp://news.eclipse.org/eclipse.webtools/<cqem61$5nn$1@www.eclipse.org>
Are you sur the editor is the JSP editor (eclipse remember last used
editor for a file)... Don't see any other reason.
I tried WTP for the first time with M2 and the JSP editor behave has
expected (i.e: code assist is context dependent).
Rich a &eacute;crit :
> I've been using the WTP for a bit &ndash; very excited to be able to see some of the WSAD like features filtering down to the Eclipse project &ndash; great work to all involved. One little thing I've been having problems with is the code assist when working on JSP's. Per the WTP tutorial, I should be seeing code assist with Java in scriptlets (and with HTML, JavaScript, etc) &ndash; but I do not. I've got all the latest and greatest installed, followed the Xerces jar installation notes, and no joy.
> Any thoughts?
> Rich
Re: Problem with code assist [message #57957 is a reply to message #57582] Thu, 23 December 2004 22:57 Go to previous message
Rich wrote:
> Ok&hellip; I'll answer my own question. I verified that I'm opening the jsp file with the JSP Source editor &ndash; and discovered how to do that (right clicking the file) and how to setup more permanent editor associations (preferences -> general).
Do you mean all (XML, HTML, JavaScript...) or do you mean just Java
and JSP? I'm pretty sure that both editors are dependent on the
file being within a Java or J2EE Web Project. Otherwise,
double-check that the "Content Assist" action is on the Edit menu
and enabled with the accelerator key you're using.
Previous Topic:HTTP Call from Plugin
Next Topic:How can I create a Web Project???
Current Time: Fri Jul 11 21:39:31 EDT 2025
Powered by FUDForum. Page generated in 0.03191 seconds
