Home » General (non-technical) » Eclipse Foundation » launch configuration framework slow refresh
launch configuration framework slow refresh [message #57574] Mon, 19 January 2009 20:31 Go to next message
Has anybody experienced a 2 second visual refresh delay from the Launch
Configuration framework?
I have a plugin that allows me to run custom services via the launch
framework.
The Run Configuration shows up with 3 tabs: Service, Input and Common.
The Input tab extends AbstractLaunchConfigurationTab. Simply put, it
creates a composite that hosts a viewer that extends TreeViewer with 2
TreeColumn. The first column is used to show the tree node, while the
second column shows the node's editable content.
I do have a few buttons to act on the tree such as Add node etc...
I set up a CellEditor that allows the user to enter data after creating a
node.
The problem manifests itself after a node is created and I call
treeViewer.editElement(treeItem.getData(), 1); // edit the second column
The visual refresh takes about 2 seonds to complete. The tree is half
blanked for that time before the entire tree shows up and the focus set at
the edit area. If I do not make the call, the result is immediate.
Also, the same viewer, if not used by the launch framework did not have
the 2 second visual refresh issue.
I'll greatly appreciate any input.
Son
Re: launch configuration framework slow refresh [message #57598 is a reply to message #57574] Tue, 20 January 2009 11:18 Go to previous message
This newsgroup is not for technical questions; it is intended for
discussions about the Eclipse foundation, not its technology.
I suggest you try the eclipse.platform newsgroup instead.
Eric
> framework.
> a node.
> at the edit area. If I do not make the call, the result is immediate.
> Son
Previous Topic:Qt now LGPL
Next Topic:BPMN Modeler Webinar - Feb. 12
Current Time: Sun Jul 06 12:09:19 EDT 2025
Powered by FUDForum. Page generated in 0.03942 seconds
