Home » Modeling » M2T (model-to-text transformation) » JET1 directive syntax
JET1 directive syntax [message #57551] Tue, 24 February 2009 10:56 Go to next message
I am modifying the templates for Ecore generation.
I see that they contain include directives of the form
<@ include="foo.javajetinc" fail="alternative" %>
<%@ start %>
//emit standard code here
<%@end %>
and
<@include=foo2.javajetinc fail="silent" %>
//carry on emitting code
Can I assume that the fail="alternative" means
"If i cannot load the include, then perform the code between <%@start%>
<%@end%>, otherwise ignore it?
And fail="silent" means
"If I cannot load the include just ignore it and carry on immediately
after it?
Which seems to be what happens when my test example is compiled....
Re: JET1 directive syntax [message #57696 is a reply to message #57551] Wed, 25 February 2009 10:18 Go to previous message
JF:
You summary is correct.
Paul
" JF" <jfrancis@his.co.uk> wrote in message
news:dafd7ed5ca7b2ebc90432aca91b16d8a$1@www.eclipse.org...
> <%@ start %>
> <%@end %>
> and
> Can I assume that the fail="alternative" means "If i cannot load the
> include, then perform the code between <%@start%> <%@end%>, otherwise
> ignore it?
> And fail="silent" means "If I cannot load the include just ignore it and
> carry on immediately after it?
Previous Topic:[JET2] c:addElement and EList / Array
Next Topic:Conditional File Generation
Current Time: Wed Jul 16 02:07:35 EDT 2025
Powered by FUDForum. Page generated in 0.03481 seconds
